[postgis-users] PostGIS Trigger doesn't work
Marcello Benigno
benigno.marcello at gmail.com
Mon Jan 28 08:24:03 PST 2013
Hi Nicolas,
No error message, just the field is not filled.
Marcello Benigno
Em 28/01/2013, às 12:48, Nicolas Ribot <nicolas.ribot at gmail.com> escreveu:
> Hi,
> Any error message ?
> Nicolas
> On 28 January 2013 16:11, Marcello Benigno <benigno.marcello at gmail.com> wrote:
>> Hello All,
>> The trigger below don't works and I need that when a new pipeline (adutoras) is inserted or updated, the procedure check what are the municipalities (municipios) that intersects the pipes and put the names of the municipalities inside the field "municipios_abastecidos".
>> CREATE OR REPLACE FUNCTION topology_fields()
>> RETURNS "trigger" AS
>> BEGIN
>> NEW.municipios_abastecidos:=(
>> SELECT string_agg(municipios.nome,', ')
>> FROM municipios, adutoras
>> WHERE ST_Intersects(adutoras.geom, municipios.geom)
>> AND adutoras.gid = NEW.gid
>> RETURN NEW;
>> END;
>> LANGUAGE 'plpgsql';
>> CREATE TRIGGER fill_topology_fields
>> BEFORE INSERT OR UPDATE ON adutoras
>> FOR EACH ROW EXECUTE PROCEDURE topology_fields();
>> Thanks in advance,
>> Marcello Benigno B. de Barros Filho
>> Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
>> Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
>> Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
>> http://profmarcello.blogspot.com
>> http://about.me/marcello.benigno
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130128/9137ed5f/attachment.html>
