[postgis-users] Tricks to find polygon/line intersection faster
Evan Martin postgresql at realityexists.net
Tue Jul 2 06:39:04 PDT 2013
I have tables of ~25,000 polygons and ~80,000 lines and I want to find
which lines intersect which polygons using PostGIS 2.1. Both are
geographies and can span the dateline. Doing this the simple way using
ST_Intersects(geog, geog) takes about 3 hours on my machine and I'd to
see if there's a way to speed this up.
I already have indexes on the geography columnsand one of them is being
used (the one on the lines). Each line only has 2 points, butthe
polygons have anywhere from 4 to 20,000 points and some of them are very
large. It would be OK to miss some of the smaller intersections (ie.
where the two only just barely intersect), but I wouldn't wantthe query
to return false positives. In fact, ideally, I'd like to find only the
lines that "substantially" intersect a polygon, eg. at least x km or x%
of the line is in the polygon, but finding any intersections at all
would be a start.
One trick I tried is ST_SimplifyPreserveTopology. I used that to create
simplified versionof the polygons (at least those that don't span the
dateline) and check those first, then if they intersect then check the
real polygons. This seems to work, but the performance gains are
marginal compared to the simple approach.
Is thereanother trick I can use to do this faster? I know
ST_Intersects() internally calls ST_Distance(), which calculates the
distance to a fraction of a metre. I don't need that kind of precision,
so surely there's some "shorcut" to be found?
Thanks,
Evan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130702/29332274/attachment.html>
