[postgis-users] st_find_extent postgresql-9.1-postgis
Tonton
to.tonton at gmail.com
Wed Jul 3 08:29:53 PDT 2013
Solved is trouble with lower case when i generate the table name
On Wed, Jul 3, 2013 at 4:53 PM, Tonton <to.tonton at gmail.com> wrote:
> hello
> i had a code that work before with postgresql-8.4-postgis (the both with
> postgis 1.5)
> maybe is not the best way to do it :
> in python i made
> cursor=connection.cursor()
> cursor.execute("SELECT st_find_extent(' " +f_table_name+ " ','
> geometry ')")
> to obtain the extend from table
> right now is making this request
> SELECT st_find_extent('grdLyon','geometry')
> but this is not working in function there is " breaking things :
> ERREUR: la relation « grdLyon » n'existe pas
> LIGNE 1 : SELECT extent("geometry") FROM "grdLyon"
> SELECT extent("geometry") FROM grdLyon seems to work in pgadmin3
> does i do somthing wrong or i need to rewrite st_find_extend whitout " for
> tablename ?
> thanks for you answers
> T.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130703/86ac1e28/attachment.html>
