[postgis-users] postgis 2.0.x segfault crashes
Sandro Santilli strk at keybit.net
Fri Jul 5 03:52:48 PDT 2013
On Fri, Jul 05, 2013 at 11:24:39AM +0200, Mario Jurcevic wrote:
> The is problem, is with the table "Bodenbedeckung__BBNachfuehrung"
> which has big polygon inside.
> Without using custom functions the system does not crashes.
> The custom functions wraps the postgis functions.
> Exception is the st_curvetoline and st_linetocurve  functions that
> during migration of postgis 1.5 to 2.0 were changed.
> Personal opinion: the new behavior is useless.
Uhm, documentation doesn't say anything about the semantic change:
 http://postgis.net/docs/ST_CurveToLine.html
 http://postgis.net/docs/ST_LineToCurve.html
How did they change ?
> We have modified the 2.0 source to include the old st_cur* st_line*
> behavior, that seems on 64 bit inside 2.0 source are not working.
So this sounds like a bug in your patches, right ?
I'll be useful to know more about the semantic change that made you
patch those functions.
--strk;
> Thanks for taking time for looking,
> Mario Jurcevic
> On 07/05/2013 10:08 AM, Sandro Santilli wrote:
> >On Thu, Jul 04, 2013 at 09:27:11PM +0200, Mario Jurcevic wrote:
> >>Sorry this one is the right:
> >>http://ubuntuone.com/202BqXg3Lvtt9zGuu3sDcx
> >The SQL file contains calls to custom functions that
> >are not available here. I handled to get the import
> >started by creating an "import_cadastre" schema, but
> >after 2.5k lines of sql the process ends with:
> >psql:interlis_import_51d5cb94e16e41.40947245.sql:2661: ERROR:  function geo_curvedtolinear(geometry) does not exist
> >LINE 1: ...o_LinearToCurved(ST_Multi(ST_BuildArea(ST_Collect(Geo_Curved...
> >Can you get the segfault crash without using custom
> >functions ?
> >--strk;
