[postgis-users] Tricks to find polygon/line intersection faster
Paul Ramsey
pramsey at opengeo.org
Fri Jul 5 18:48:25 PDT 2013
Without seeing your data it's quite hard to say. Many large things vs
many large things yields a problem where indexes and so on don't have
a lot of leverage on the problem.
On Tue, Jul 2, 2013 at 6:39 AM, Evan Martin
<postgresql at realityexists.net> wrote:
> Hi,
> I have tables of ~25,000 polygons and ~80,000 lines and I want to find which
> lines intersect which polygons using PostGIS 2.1. Both are geographies and
> can span the dateline. Doing this the simple way using ST_Intersects(geog,
> geog) takes about 3 hours on my machine and I'd to see if there's a way to
> speed this up.
> I already have indexes on the geography columns and one of them is being
> used (the one on the lines). Each line only has 2 points, but the polygons
> have anywhere from 4 to 20,000 points and some of them are very large. It
> would be OK to miss some of the smaller intersections (ie. where the two
> only just barely intersect), but I wouldn't want the query to return false
> positives. In fact, ideally, I'd like to find only the lines that
> "substantially" intersect a polygon, eg. at least x km or x% of the line is
> in the polygon, but finding any intersections at all would be a start.
> One trick I tried is ST_SimplifyPreserveTopology. I used that to create
> simplified version of the polygons (at least those that don't span the
> dateline) and check those first, then if they intersect then check the real
> polygons. This seems to work, but the performance gains are marginal
> compared to the simple approach.
> Is there another trick I can use to do this faster? I know ST_Intersects()
> internally calls ST_Distance(), which calculates the distance to a fraction
> of a metre. I don't need that kind of precision, so surely there's some
> "shorcut" to be found?
> Thanks,
> Evan
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
