[postgis-users] OpenBSd installation problem
dustymugs
dustymugs at gmail.com
Wed Jul 10 14:48:09 PDT 2013
After reading back through your initial email, ignore the missing
PostgreSQL symbols as the problem really is the loading of
rtpostgis-2.2.so in PostgreSQL.
Based upon the ldd output, all the libraries that your rtpostgis-2.2.so
library depends on is found.
I don't believe my advice will be of much value as I haven't used *BSD
in a very long time...
-bborie
On 07/10/2013 02:08 PM, Marcelo Bacha wrote:
> Here´s the output:
> # ldd /usr/local/pgsql/lib/rtpostgis-2.2.so
> /usr/local/pgsql/lib/rtpostgis-2.2.so:
> Start End Type Open Ref GrpRef Name
> 0ee98000 2eebd000 dlib 1 0 0 /usr/local/pgsql/lib/
> rtpostgis-2.2.so
> 08a43000 28cec000 rlib 0 1 0
> /usr/local/lib/libgdal.so.18.0
> 041ef000 241f9000 rlib 0 2 0
> /usr/local/lib/libgeos_c.so.8.8
> 003f6000 20400000 rlib 0 1 0 /usr/local/lib/libproj.so.7.0
> 0e834000 2e838000 rlib 0 1 0 /usr/local/lib/libjson.so.1.1
> 0a36a000 2a391000 rlib 0 2 0
> /usr/local/lib/libxml2.so.14.0
> 06045000 2604c000 rlib 0 5 0 /usr/lib/libz.so.4.1
> 0fce8000 2fdc8000 rlib 0 5 0
> /usr/local/lib/libiconv.so.6.0
> 059df000 259e8000 rlib 0 9 0 /usr/lib/libm.so.7.1
> 064e4000 26526000 rlib 0 2 0 /usr/local/lib/libgeos.so
> 0dfef000 2dffd000 rlib 0 1 0 /usr/lib/libsqlite3.so.21.0
> 07bdf000 27be4000 rlib 0 1 0 /usr/lib/libexpat.so.10.0
> 007b8000 207c7000 rlib 0 1 0
> /usr/local/lib/libjasper.so.2.1
> 0ae63000 2ae67000 rlib 0 1 0 /usr/local/lib/libgif.so.5.4
> 077d1000 277d7000 rlib 0 1 0
> /usr/local/lib/libjpeg.so.64.0
> 0978e000 29795000 rlib 0 1 0
> /usr/local/lib/libpng.so.15.14
> 09594000 2959c000 rlib 0 1 0 /usr/local/lib/libpq.so.5.5
> 00a2d000 20a39000 rlib 0 1 0
> /usr/local/lib/libcurl.so.23.0
> 05f63000 25f8f000 rlib 0 2 0 /usr/local/lib/libidn.so.17.0
> 02e03000 22e07000 rlib 0 3 0 /usr/local/lib/libintl.so.6.0
> 0ab0d000 2ab1a000 rlib 0 3 0 /usr/lib/libssl.so.19.0
> 0d71c000 2d75b000 rlib 0 3 0 /usr/lib/libcrypto.so.22.0
> 094ce000 294fc000 rlib 0 3 0 /usr/lib/libstdc++.so.55.0
> Indeed, there´s no shared object from /usr/local/pgsql/lib, is this correct?
> Anyway, I´ve included this path at the /etc/rc.conf shlib_dirs variable, so
> rc execute the proper ldconfig command, which is just OK:
> # ldconfig -r | grep pgsql
> search directories:
> /usr/lib:/usr/X11R6/lib:/usr/local/lib:/usr/local/pgsql/lib
> 328:-lpgtypes.3.3 => /usr/local/pgsql/lib/libpgtypes.so.3.3
> 329:-lecpg.6.4 => /usr/local/pgsql/lib/libecpg.so.6.4
> 331:-lecpg_compat.3.4 => /usr/local/pgsql/lib/libecpg_compat.so.3.4
> Marcelo
> On Wed, Jul 10, 2013 at 5:06 PM, dustymugs <dustymugs at gmail.com> wrote:
>> Marcelo,
>> See if rtpostgis-2.2.so can find the PostgreSQL libs.
>> -bborie
>> On 07/10/2013 12:32 PM, Marcelo Bacha wrote:
>>> Thanks Bborie.
>>> I went back to PostgreSQL, to check the warnings from compilation. I
>>> Corrected a couple of things, applied a recent patch for the configure
>>> properly recognize sys/ucred.h, and so on, but nothing changed the
>>> situation.
>>> Here´s how it´s configured:
>>> ./configure --enable-depend --with-openssl --with-libxml --with-libxslt
>>> --with-perl --enable-debug --disable-thread-safety
>>> I´m running out of ideas...
>>> Best,
>>> Marcelo
>>> On Mon, Jul 1, 2013 at 5:19 PM, Bborie Park <dustymugs at gmail.com> wrote:
>>>> Marcelo,
>>>> Those missing symbols are all from PostgreSQL. You'll want to make
>>>> sure the PostgreSQL libs and dev files are provided.
>>>> -bborie
>>>> On Mon, Jul 1, 2013 at 1:17 PM, Marcelo Bacha <dronsz at gmail.com> wrote:
>>>>> Hi,
>>>>> This is my first posting, I´m new to Postgis. I´ve seen similar
>> problems
>>>>> related in lists all around, but this one, I couldn´t manage to solve.
>>>>> I have an OpenBSD 5.3 server, with PostgreSQL 9.2.4 on it, which always
>>>>> worked fine. I have to transfer some geospatial databases from a
>> Windows
>>>>> server, so I downloaded Postgis from the source (I needed the latest
>>>>> versions), configured, compiled & installed it.
>>>>> Everything seems to be fine, but when I try to create the postgis
>>>> extension
>>>>> (with raster support) on psql:
>>>>> postgres=# CREATE EXTENSION postgis;
>>>>> ERROR: could not load library "/usr/local/pgsql/lib/
>> rtpostgis-2.2.so
>>>>> dlopen (/usr/local/pgsql/lib/rtpostgis-2.2.so) failed: Cannot load
>>>> specified
>>>>> object
>>>>> The paths seems all to be OK:
>>>>> # ls -l /usr/local/pgsql/lib/*post*
>>>>> -rwxr-xr-x 1 root wheel 1276039 Jul 1 16:50
>>>>> /usr/local/pgsql/lib/postgis-2.2.so
>>>>> -rwxr-xr-x 1 root wheel 1208861 Jul 1 16:50
>>>>> (I know it´s the development, and not the stable release, but the
>> results
>>>>> are the same with all other releases.)
>>>>> When I try to preload the rtpostgis shared object setting the
>> LD_PRELOAD
>>>>> environment variable, I get this on psql:
>>>>> $ psql
>>>>> psql:/usr/local/pgsql/lib/rtpostgis-2.2.so: undefined symbol
>>>>> 'CurrentMemoryContext'
>>>>> 'SPI_tuptable'
>>>> 'SPI_result'
>>>>> 'InterruptPending'
>>>>> 'SPI_processed'
>>>>> psql (9.2.4)
>>>>> Didn´t find any further useful info setting LD_DEBUG (I may list the
>>>> output
>>>>> if necessary, anyway).
>>>>> Any hint on how to solve this? I´m running out of ideas.
>>>>> Thanks in advance,
>>>>> Marcelo
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
