[postgis-users] ST_Intersection Problems
BladeOfLight16 bladeoflight16 at gmail.com
Fri Jul 12 10:55:34 PDT 2013
I actually have the geometry pairs for 4 of the "non-noded intersection"
errors, and I could probably get the "no outgoing dirEdge" ones with a
little work. I double checked, and ST_IsValid returns true on all of the
ones I have. ST_Segmentize(geom, 1) made one of the "non-noded" errors go
away, but not the others. ST_Snap(geom, 0.01) didn't change any of those 4.
Combining the two didn't help any, either. Combined
ST_Segmentize(ST_Snap(geom, 0.1), 0.1) just ran for a very long time (even
after I tried to cancel). (This data is in UTM 15, by the way.) I suppose I
could try playing around with the parameters some more and seeing if that
helps anything, but my attempts thus far (including prior to this
discussion) suggest that while those kinds of modifications might fix the
error with the currently failing polygons, they will cause failures on
other polygons.
I don't know if I'll have time to try upgrading GEOS a second time or not.
As I said, I abandoned 3.4dev when it didn't fix my initial errors from
ST_Union. May I ask why you suggest 3.3.9dev over 3.4dev, and would you
like me to file a report if I don't have a chance to test with the dev
versions? How would you suggest delivering the hex EWKBs if so? They're
quite long.
Thanks for your help.
On Fri, Jul 12, 2013 at 4:18 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, Jul 11, 2013 at 10:09:58PM -0400, BladeOfLight16 wrote:
> > TL;DR Version:
> > ST_Intersection is blowing up with errors about "non-noded intersections"
> > and "no outgoing dirEdge" on my polygons. A bunch of sordid details about
> > my data later, what can I try to make it stop throwing
> TopologyExceptions?
> 1) Make sure all your input geometries are valid (ST_IsValid, ST_MakeValid)
> 2) Upgrade to latest interim GEOS version (3.3.9dev r3828 is a good choice)
> 3) Try reducing almost-equal-but-not-really situations
>    (ST_Segmentize, ST_SnapToGrid)
> 4) If all of the above fails, isolate the smallest input triggering the
>    problem and report it into a bug report on http://trac.osgeo.org/geos
> Good luck !
> (Notes on the gory details below)
> > Some gory details:
> > The data I have comes from GPS, and it hasn't been cleaned up very much
> (if
> > at all). Blame my client for that; I don't have any control over that end
> > of things. Rather, I'm doing a lot of processing on that front. I'm
> calling
> > ST_IsValid on every polygon that comes into the database, and if
> > ST_MakeValid doesn't fix a bad shape, the shape doesn't make it into the
> > database or is removed. So anything that isn't valid according to
> > ST_IsValid either doesn't make it to the database or gets removed. (It's
> a
> > Python scripted import process from shapefiles using GDAL 1.9.2.)
> > Anyway, I keep getting TopologyExceptions when intersecting
> multipolygons.
> > The main one I've seen is "Found a non-noded intersection" between two
> line
> > segments. Sometimes, it reports a pair of line segments that are
> identical
> > (same pair of endpoints) or with all 4 endpoints the same. I suppose it
> > could be rounding them off before printing them out, but I'm not sure. I
> It necessarely rounds off for printing. Real coordinate values are 64bit
> floating points.
> > know my data isn't great, but it seems to me that ST_Intersection should
> be
> > able to deal with non-noded intersecting boundaries on a pair of polygons
> > that are known to be valid even if there really are non-identical line
> > segments here. I've also just seen a new error about "no outgoing
> dirEdge".
> > I'm pretty sure these exceptions bubble up from GEOS. I can't imagine
> that
> > ST_Intersection is just this broken, but I don't know what could be wrong
> > with my data. Are the errors saying that my input polygons are invalid? I
> > don't even know what "no outgoing dirEdge" means. I've worked around some
> > of these problems by trying out various processing functions, but they
> seem
> > to keep cropping up on new shapes all the time.
> All the errors you report come from GEOS.
> The "no outgoing dirEdge" one is likely due to invalid input, but the
> invalid input may be produced internally by GEOS itself. There are
> known cases like this on trac. You can get more details about the failure
> rebuilding GEOS with GEOS_DEBUG_BINARYOP defined
> (see include/geos/geom/BinaryOp.h)
> > At one time, I tried upgrading to a nightly build of GEOS 3.4, but since
> > that didn't solve my "non-noded intersection" errors at the time, I
> > abandoned it. At that time, the errors were coming from ST_Union on a
> bunch
> > of line work, in fact. When upgrading didn't work, I ended up taking my
> > line work, breaking it down into individual segments (as in 2 points per
> > segment), and eliminating duplicate line segments (according to
> ST_Equals).
> > After that, the union worked, which strengthens the argument that the
> > problem has to do with duplicate line segments somewhere, at least in my
> > mind.
> They were probably almost identical but not really so.
> Next time keep them around, but have them printed in HEXWKB form to avoid
> the roundoff.
> --strk;
>  http://www.cartodb.com - Map, analyze and build applications with your
> data
>                                        ~~ http://strk.keybit.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130712/de4ad3a9/attachment.html>
