[postgis-users] postgres and postgis upgrade
Marcos Cano mcano at stsa.info
Tue Jul 16 14:03:14 PDT 2013
thank you very much for your help and time, so my case is the second one...
but that does not matter now because after doing the whole process of
dumping and perl_restore, it is not working, some databases are empty after
the dump and i see a lot of :
ERROR:  constraint "spatial_ref_sys_srid_check" of relation
"spatial_ref_sys" does not exist
ERROR:  constraint "spatial_ref_sys_pkey" of relation "spatial_ref_sys"
does not exist
ERROR:  type "histogram2d" already exists
ERROR:  function "al_set_stat_celplan" already exists with same argument
types
ERROR:  function "al_set_stat_leasing" already exists with same argument
types
ERROR:  function "round_time" already exists with same argument types
ERROR:  function "array_accum" already exists with same argument types
ERROR:  relation "ad_id_seq" already exists
ERROR:  relation "agosto_2012" already exists
in the logfile
so idk why im not able to really  (dump or restore??) i think it might be
the restore process, as i obviously dont have full control over the large
script postgis_restore.pl
On Fri, Jul 12, 2013 at 8:52 PM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>  I answer to your first question about how to change PATH variable without
> screwing it.
> There is another way to change PATH variable, but only for one account at
> the time. You have to add the following lines to a file called
> .bash_profile (don't miss the dot (.) at the beginning) located in your
> $HOME or ~ directory:
> PATH=/usr/local/pgsql9.2.4/bin/:$PATH
> export PATH
> By this way, you only add a path to the PATH variable without removing the
> old pgsql path (who seem be /usr/local/pgsql/bin/ in your system). You
> might be aware that this way can make confusion in order to know which
> version of pgsql command will be called. I'm not sure, but I think that the
> order of the PATH command is as we read it, e.g. from left to right and
> from top to bottom. That's why I add pgsql9.2.4 path at the very beginning
> of the PATH variable. Remember also that the pgsql9.2.4 path will be
> accessible only for the account where you put your .bash_profile file.
> Your second question is about to put or not the database in read-only mode
> before pg_dump -Fc. I want to tell you that you learned me a new feature in
> PostgreSQL that I didn't hear before. But, I read informations on internet
> and I learned that it's really a PostgreSQL feature.
> I suppose you talk about the source database. There are some informations
> I don't know about your installation. How large is your setup? If  you have
> a small database in a university department where you can limit the access
> of the database to only one or two computers located in the same school
> room , it's obvious that you just need to turn off those computers, backup
> the data (pg_dump -Fc) on the server without read-only mode, restore them
> to the new database and set the new connection of those computers before
> the users can access the new database and that's it. But if it's a database
> who is the back-end of a large web site with many redundant servers, I
> suppose in that case that it's better first to put the web site offline,
> disconnect all the users from the source database before doing pg_dump -Fc
> on the master DB, restoring the data, propagate the new connection link,
> make some "home" tests and re-open the web site after. I think that the
> question to put or not in read-only mode your PostgreSQL database before
> your pg_dump -Fc is about to know if you have or not the control on the
> access of the database. It's obvious that you should not have modifications
> of the data in your source database between the moment you back them up and
> you restore them to your new database.
> In my experience, I back up and restore regularly a small database on a
> desktop computer in a small office. I do it when users are not there and I
> never put PostgreSQL in read-only mode. If you experience the situation of
> a large web site, I think it's really a good choice to ask your question to
> and to be helped by a professionnal PostgreSQL specialist as EnterpriseDB.
> Hope it will be useful
> Sylvain Racine
> Le 2013-07-12 13:51, Marcos Cano a écrit :
>  do you think putting the database in a read-only mode before the pg_dump
> -Fc should be a good idea??
>  thank you
> On Wed, Jul 10, 2013 at 2:56 PM, Marcos Cano <mcano at stsa.info> wrote:
>>  i think i screw it last time... i did not remember to do the echo $PATH
>> in the postgres user...my bad ...
>>  when i do it in the postgres user the outcome is:
>> /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/pgsql/bin/
>>  so  it is pointing to the 8.3 version (pgsql) my 9.2.4 is
>> so how can i change the env variable without screwing it really bad?
>> thanks for all your support
>> On Tue, Jul 9, 2013 at 5:50 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>> On 2013-07-08 16:25, Marcos Cano wrote:
>>> ubuntu server 12.04... and when i do "echo $PATH" the environment
>>> variable is blank
>>>   Really weird...
>>> Anyway, what you could do first it's to rename the 8.3.2 command to
>>> disable it. Locate "psql" command of your PostgreSQL version 8.3.2, ex.
>>> /usr/bin. Inside the directory, type "sudo mv -i psql psql-8.3.2". Now,
>>> type "psql --version". If the command is found and the version is changed
>>> to 9.2.4, your lucky. If a "command not found" message appears, you have to
>>> add the path of your new version of PostgreSQL commands to your PATH
>>> variable. Here below the process...
>>> To edit PATH variable for your whole Ubuntu system, type "sudo gedit
>>> /etc/environment" (gedit or your favorite editor). A line like
>>> «PATH="....."» should appear. Add your 9.2.4 command path to the variable.
>>> Save the file, close your terminal and reopen it and it should work. Be
>>> carefull in your editing. You could scrap your PATH variable and lose all
>>> your Linux commands. You should make a copy of this file in your /home
>>> directory before editing it. If you scrap it, you could type the full path
>>> of your Linux command, e.g. "sudo /usr/bin/gedit /etc/environment" to
>>> correct the problem or reinstall the backup file.
>>> If the path of your 8.3.2 version is NOT a general path like "/usr/bin"
>>> or "/usr/local/bin", you could remove it from your PATH environment
>>> variable to disable all old PostgreSQL commands. But if it is, you must
>>> rename all the old PostgreSQL command to disable them, ex. pg_dump,
>>> pg_restore, etc.
>>> After those operations, you must type the full path to access old 8.3.2
>>> PostgreSQL commands and type only the command without full path to access
>>> new 9.2.4 PostgreSQL commands.
>>> Hope it will be usefull
>>> Sylvain Racine
>>> On Mon, Jul 8, 2013 at 9:12 AM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>>>  Sorry for the delay. It was the week end. So I closed the computer. To
>>>> disable psql command for 8.3.2 version, you have to remove the whole path
>>>> of your old PostgreSQL installation from you PATH variable and replace it
>>>> by the new one. Depending of the type of OS you use, ex. on Linux, type
>>>> "echo PATH" to see the paths associated to your system or on Windows, type
>>>> just "PATH" to see the paths.
>>>> If you need any help to remove the PostgreSQL 8.3.2 version from PATH
>>>> variable, please indicate the type of OS you use.
>>>> Regard
>>>> Sylvain Racine
>>>> Le 2013-07-05 11:41, Marcos Cano a écrit :
>>>>  so when running my script everything went well except that when i
>>>> run  "psql --version" it still runs the 8.3.2 version... so to do psql
>>>> (9.2.4) i have to indicate the full path to pgsql9.2.4/bin/psql ..
>>>>  any idea on how to fix this?
>>>> On Thu, Jul 4, 2013 at 4:07 PM, Racine, Sylvain <syracine at sympatico.ca>wrote:
>>>>>  The postgis.sql is a part of the restore process. Because you'll make
>>>>> hard upgrade of PostGIS, you have to use Perl script
>>>>> postgis_restore.pl. This script removes old PostGIS functions from
>>>>> your backup and installs the new ones in the new database. Then, you have
>>>>> to give the path of postgis.sql (or lwpostgis.sql) when you call
>>>>> postgis_restore.pl on command line.
>>>>> I'm not really fan of the new procedure using "CREATE EXTENSION
>>>>> postgis". It's an automatic process enabled in PostgreSQL 9.1 and more.
>>>>> With this procedure, you have to use PostGIS who is embedded with
>>>>> PostgreSQL package. I encountered earlier some errors when I tried to
>>>>> install PostGIS using this procedure on a Windows box. But, using the old
>>>>> procedure I described above, I had the complete control of the installation
>>>>> and I always got a functionnal database, even with PostgreSQL 9.2.
>>>>> Regard
>>>>> Sylvain Racine
>>>>> Le 2013-07-04 13:06, Marcos Cano a écrit :
>>>>> well i guess while installing and making the postgis i installed it
>>>>> against the 9.2.4  (with this : "./configure
>>>>> --with-pgconfig=/usr/local/pgsql9.2.4/bin/pg_config" )
>>>>> the postgis.sql you mention is to create a spatially enabled database?
>>>>> or is it part of the restore process?
>>>>>  and yes im using the full path to the command to do everything.
>>>>>  thank you very much i really appreciate it
>>>>> On Thu, Jul 4, 2013 at 9:51 AM, Racine, Sylvain <syracine at sympatico.ca
>>>>> > wrote:
>>>>>>  You have to use pg_dump version 8.3.2 to backup your database,e.g.
>>>>>> the same version of your source database. To restore, use the Perl script
>>>>>> and postgis.sql given with  Postgis 2.0.4. This script calls pg_dump
>>>>>> command. It must be pg_dump version 9.2.4, e.g. your destination database
>>>>>> version. Use "pg_dump --version" to know the version of your command.
>>>>>> You seem use 2 differents versions of PostgreSQL and PostGIS on the
>>>>>> same computer. To get a particular version of a command, type the whole
>>>>>> path of the command.
>>>>>> Regard
>>>>>> Sylvain Racine
>>>>>> Le 2013-07-04 10:07, Marcos Cano a écrit :
>>>>>> what version of pg_dump should i use?... i tried the 8..3.2 and i
>>>>>> think it works, but trying the suggested one, wich is the latest (9.2.4)
>>>>>> seems just to not work properly because it does not dump my entire database
>>>>>> (i assume is because of the mismatch of postgis versions)
>>>>>> On Wed, Jul 3, 2013 at 12:00 PM, Paragon Corporation <lr at pcorp.us>wrote:
>>>>>>>  Yes (custom dump of 8.3.2 + pgis, create new postgis 2.0.4 in
>>>>>>> 9.2.4 and restore backup) is the recommended way.  9.2.4 + 1.5.8 are
>>>>>>> borderline compatible so I would avoid that mix and if your ultimate goal
>>>>>>> is to go to 2.0, 1.5.8 requires a hard upgrade anyway so not worth the
>>>>>>> hassle.
>>>>>>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>>>>>>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Marcos Cano
>>>>>>> *Sent:* Wednesday, July 03, 2013 10:43 AM
>>>>>>> *To:* postgis-users at lists.osgeo.org
>>>>>>> *Subject:* [postgis-users] postgres and postgis upgrade
>>>>>>>   So I'm trying to upgrade Postgres and postgis.. My current
>>>>>>> versions are 8.3.2 and 1.3 respectively. And trying to upgrade to
>>>>>>> postgis 2.0.4 and Postgres 9.2.4
>>>>>>>  I've been trying a lot of options like:hard upgrade of postgis to
>>>>>>> 1.5.8 in the Postgres 8.3 ( as I'm sure that version of postgis is
>>>>>>> compatible with Postgres 8.3 and 9.2.4)
>>>>>>> Then installing postgres 9.2.4 + postgis 1.5.8 and do a pg_upgrade
>>>>>>> and finally do a hard upgrade of postgis to 2.0.4 in the postgres 9.2.4
>>>>>>> installation. It  seems to work until an error happened during the
>>>>>>> pg_upgrade
>>>>>>> Your installation contains the "name" data type in user tables.
>>>>>>>  This data type changed its internal alignment between your old and new
>>>>>>> clusters so this cluster cannot currently be upgraded.  You can remove the
>>>>>>> problem tables and restart the upgrade.
>>>>>>>  So I tried another option but I don't know if this will work.
>>>>>>> Here's my idea:
>>>>>>>  Do a custom dump of the DB in Postgres 8.3.2 + pgis 1.3 .
>>>>>>>  Install 9.2.4 with postgis 2.0.4
>>>>>>> And do a restore with perl script included in the postgis binary
>>>>>>> folder  (perl utils/postgis_restore.pl)
>>>>>>>  do you think it will work?
>>>>>>> _______________________________________________
>>>>>>> postgis-users mailing list
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>>> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130716/e77ae973/attachment.html>
