[postgis-users] PostGIS 1.5 Upgrade Path
Wilkins, Brian bwilkins at harris.com
Thu Jul 18 06:16:20 PDT 2013
Thanks Regina. I want to stay with the Red Hat repo for now. My PostGIS tables exist in the same database as a few other tables. If I use pg_dump to dump the database, can I use the restoration utility from PostGIS to reload the database? I tried dumping, upgrading to 8.4 and reloading on a test server yesterday. It did not restore cleanly using pg_restore.
Brian
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Paragon Corporation
Sent: Wednesday, July 17, 2013 12:03 AM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] PostGIS 1.5 Upgrade Path
Brian,
First off -- is there a reason you are choosing to upgrade to PostgreSQL 8.4 instead of something newer like PostgreSQL 9.2.
The reason I ask is PostgreSQL 8.4 is going to reach EOL in a year time (July 2014) http://www.postgresql.org/support/versioning/
 so in a year or so  you'll probably want to upgrade again so you can keep security patches up to date.
That said -- going from 8.1 to 9.2 is the same amount of work as going from 8.1 to 8.4, so you might as well go all the way or as far as you can since the hardest part is the dump reload.
I also wouldn't bother with going to 1.5 since to go from 1.5 to 2 series requires another dump reload.  Go straight to 2.0 or 2.1 when it comes out (which will be in a week or so) if you can.
If its because of the distribution you are using why limit yourself? I would highly advice using the yum.postgresql.org repository: http://yum.postgresql.org/  since they've got the latest PostgreSQL and PostGIS that money can't buy and keep up with patches :)
Thanks,
Regina
http://www.postgis.us
http://www.paragoncorporation.com
http://postgis.net
From: postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Wilkins, Brian
Sent: Tuesday, July 16, 2013 1:47 PM
To: 'postgis-users at lists.osgeo.org'
Subject: [postgis-users] PostGIS 1.5 Upgrade Path
All,
It is my understanding that I will need to take the hard upgrade path since I am currently using PostgreSQL 8.1 and PostGIS 1.3. Should I upgrade to PostGIS 1.5 first and then PostgreSQL 8.4? I am using Red Hat 5.8.
Thanks
Brian
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130718/3093393b/attachment.html>
