[postgis-users] Unable to complete checks on Solaris x64
Dechaux Eric CEN (BCQ STIG)
eric.dechaux at gendarmerie.interieur.gouv.fr
Mon Jul 22 13:44:52 PDT 2013
I need to install PostGIS on a Solaris 10 X64 powered system.
I have successfully built and installed a 32 bits version by I am stuck on the 64 bits build.
The configure part goes without trouble :
PostGIS is now configured for i386-pc-solaris2.10
-------------- Compiler Info -------------
C compiler: gcc -m64 -g -O2 -std=gnu99
C++ compiler: g++ -m64 -g -O2
SQL preprocessor: /usr/sfw/bin/cpp -traditional-cpp -P
-------------- Dependencies --------------
GEOS config: /opt/stig/idicsi-2.0/bin/amd64/geos-config
GEOS version: 3.3.8
GDAL config: /opt/stig/idicsi-2.0/bin/amd64/gdal-config
GDAL version: 1.10.0
PostgreSQL config: /opt/stig/idicsi-2.0/bin/amd64/pg_config
PostgreSQL version: PostgreSQL 9.2.4
PROJ4 version: 48
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.6.23
JSON-C support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
dblatex:
convert: /usr/sfw/bin/convert
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
As well as the make part :
gmake[2]: Leaving directory `/opt/stig/idicsi-2.0/src/postgis-2.0.3/extensions/postgis_topology'
gmake[1]: Leaving directory `/opt/stig/idicsi-2.0/src/postgis-2.0.3/extensions'
PostGIS was built successfully. Ready to install.
However, the make check fails with two kind of errors during the regress tests :
PostgreSQL 9.2.4 on i386-pc-solaris2.10, compiled by gcc (GCC) 3.4.3 (csl-sol210-3_4-branch+sol_rpath), 64-bit
Postgis 2.0.3 - r11128 - 2013-07-22 18:47:57
GEOS: 3.3.8-CAPI-1.7.8
PROJ: Rel. 4.8.0, 6 March 2012
Running tests
lwgeom_regress .. failed (diff expected obtained: /tmp/pgis_reg/test_27_diff)
tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_66_diff)
typmod .. failed (diff expected obtained: /tmp/pgis_reg/test_67_diff)
concave_hull .. failed (diff expected obtained: /tmp/pgis_reg/test_72_diff)
hausdorff .. failed (diff expected obtained: /tmp/pgis_reg/test_73_diff)
sharedpaths .. failed (diff expected obtained: /tmp/pgis_reg/test_78_diff)
snap .. failed (diff expected obtained: /tmp/pgis_reg/test_79_diff)
clean .. failed (diff expected obtained: /tmp/pgis_reg/test_82_diff)
relate_bnr .. failed (diff expected obtained: /tmp/pgis_reg/test_83_diff)
in_geojson .. ok
uninstall .. failed (Count of object before install (4061) != count after uninstall (4064))
Run tests: 85
Failed: 10
Here is the diff for the first failure :
--- lwgeom_regress_expected Mon Feb 27 23:08:12 2012
+++ /tmp/pgis_reg/test_27_out Mon Jul 22 20:49:06 2013
@@ -1,5 +1,5 @@
BOX(0 0.1,11 12)
-BOX3D(0 0.1 -55,11 12 12)
+BOX3D(0 0.1 -0.04,11 12 12)
11184
15824
20464
I really don't understand why the x86 build works OK but not the x64, but I think it is a minor error.
All other failures, on the contrary, crashed the postgresql process. Here is what it shown in the postgresql log file for the tickets checks :
LOG: processus serveur (PID 669) a été arrêté par le signal 11
DÉTAIL: Le processus qui a échoué exécutait : SELECT '#168', ST_NPoints(g), ST_AsText(g), ST_isValidReason(g)
FROM ( VALUES
('01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF'::geometry)
) AS v(g);
LOG: arrêt des autres processus serveur actifs
ATTENTION: arrêt de la connexion à cause de l'arrêt brutal d'un autre processus serveur
DÉTAIL: Le postmaster a commandé à ce processus serveur d'annuler la transaction
courante et de quitter car un autre processus serveur a quitté anormalement
et qu'il existe probablement de la mémoire partagée corrompue.
ASTUCE : Dans un moment, vous devriez être capable de vous reconnecter à la base de
données et de relancer votre commande.
LOG: tous les processus serveur se sont arrêtés, réinitialisation
Basically the process coredump and postgresql restarts.
As the coredumps keeps overwriting, I can only analyses the last crash :
LOG: processus serveur (PID 26050) a été arrêté par le signal 11
DÉTAIL: Le processus qui a échoué exécutait : SELECT origin,caseno,
st_equals(st_collectionextract(st_makevalid(orig),1), st_collectionextract(valid,1)) AND
st_equals(st_collectionextract(st_makevalid(orig),2), st_collectionextract(valid,2)) AND
st_equals(st_collectionextract(st_makevalid(orig),3), st_collectionextract(valid,3)),
st_isvalid(st_makevalid(orig)),
(st_isvaliddetail(orig)).valid
FROM clean_cases;
-bash-3.2$ file core
core: ELF 64-bit LSB core file AMD64 Version 1, from 'postgres'
-bash-3.2$ pstack core
core 'core' of 26050: /opt/stig/idicsi-2.0/bin/amd64/postgres -D /tmp/postgis-2.0.313818
00000000001b6cad ???????? ()
fffffd7ffed11f09 _SUNW_Unwind_RaiseException () + 46
fffffd7ffb7dc79e __cxa_throw () + 5e
fffffd7ffb923ea1 _ZN4geos4geom10LinearRing20validateConstructionEv () + 161
fffffd7ffb9247ea _ZN4geos4geom10LinearRingC1EPNS0_18CoordinateSequenceEPKNS0_15GeometryFactoryE () + 6a
fffffd7ffb920115 _ZNK4geos4geom15GeometryFactory16createLinearRingEPNS0_18CoordinateSequenceE () + 35
fffffd7ffe6861d2 GEOSGeom_createLinearRing_r () + 22
fffffd7ffe7338a3 LWGEOM2GEOS () + 1b3
fffffd7ffe734fb8 lwgeom_make_valid () + 48
fffffd7ffe6f2c68 ST_MakeValid () + 68
00000000005ff6cf ExecMakeFunctionResultNoSets () + bf
00000000005ff67f ExecMakeFunctionResultNoSets () + 6f
0000000000600563 ExecEvalAnd () + 53
0000000000603ae9 ExecProject () + 159
0000000000603e4c ExecScan () + 10c
00000000005fd01d ExecProcNode () + 27d
00000000005fb979 standard_ExecutorRun () + a9
00000000006ce674 PortalRunSelect () + 94
00000000006cf018 PortalRun () + 2a8
00000000006cc193 exec_simple_query () + 273
00000000006cd3a4 PostgresMain () + 994
000000000068c4ec ServerLoop () + 90c
000000000068e2dc PostmasterMain () + 63c
000000000062d578 main () + 508
00000000004dfcbc _start () + 6c
-bash-3.2$ mdb core
Loading modules: [ ld.so.1 libc.so.1 libuutil.so.1 ]
> ::stack
0x1b6cad()
libc.so.1`_SUNW_Unwind_RaiseException+0x46()
libstdc++.so.6.0.3`__cxa_throw+0x5e()
libgeos-3.3.8.so`_ZN4geos4geom10LinearRing20validateConstructionEv+0x161()
libgeos-3.3.8.so`_ZN4geos4geom10LinearRingC1EPNS0_18CoordinateSequenceEPKNS0_15GeometryFactoryE+0x6a()
libgeos-3.3.8.so`_ZNK4geos4geom15GeometryFactory16createLinearRingEPNS0_18CoordinateSequenceE+0x35()
libgeos_c.so.1.7.8`GEOSGeom_createLinearRing_r+0x22()
postgis-2.0.so`LWGEOM2GEOS+0x1b3()
postgis-2.0.so`lwgeom_make_valid+0x48()
postgis-2.0.so`ST_MakeValid+0x68()
ExecMakeFunctionResultNoSets+0xbf()
ExecMakeFunctionResultNoSets+0x6f()
ExecEvalAnd+0x53()
ExecProject+0x159()
ExecScan+0x10c()
ExecProcNode+0x27d()
standard_ExecutorRun+0xa9()
PortalRunSelect+0x94()
PortalRun+0x2a8()
exec_simple_query+0x273()
PostgresMain+0x994()
ServerLoop+0x90c()
PostmasterMain+0x63c()
main+0x508()
_start+0x6c()
If I understand well, the crash occurs inside GEOS, in the LinearRing constructor, inside the validateConstruction method.
Has somebody seen this king of crash ? Can it comes from my GEOS build ?
Best regards
Eric DECHAUX
Ce message électronique et tous les fichiers attachés qu'il contient sont confidentiels et destinés exclusivement à l'usage de la personne à laquelle ils sont adressés. Si vous avez reçu ce message par erreur, merci de le retourner à son émetteur. La publication, l'usage, la distribution, l'impression ou la copie non autorisée de ce message et des attachements qu'il contient sont strictement interdits.
En cas d'urgence, composez le 17 ou le 112.
Afin de contribuer au respect de l'environnement, merci de n'imprimer cet e-mail qu'en cas de necessite.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual to whom it is addressed. If you have received this email in error please send it back to the person that sent it to you. Unauthorized publication, use, dissemination, forwarding, printing or copying of this email and its associated attachments is strictly prohibited.
In case of emergency, dial number 17 or 112.
To contribute to the environmental protection, please print this e-mail only if necessary.
