[postgis-users] Left of/Right of test
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jul 23 08:23:13 PDT 2013
On 7/23/2013 11:16 AM, Denis Rouzaud wrote:
> I was thinking of the case where you have something like his:
> *         X          *
> ******A     B*********
I added A & B to the linestring above. Linestrings have an implied
direction based on their direction of digitization. So in the above
example if the line start point is A and the line end point is B then X
is on right side of the line as you walk along the line.
The way I would solve the right/left-ness of a line is to project the
point X onto the line AB then isolate the segment within the AB and
compute the cross product of the segment of AB and a line from the start
of segment to X and if if Z is negative then the point is on right
positive=left, zero it is one the centerline.
-Steve
> This might be a particular case, but I don't know the answer (as a human
> Or did I miss your point ?
> Cheers,
> Denis
> On 07/23/2013 05:03 PM, Andreas Neumann wrote:
>> Hi Denis,
>> Thank you for your reply.
>> Actually I really want to test a LINESTRING against POLYGON centroids
>> (determined with ST_PointOnSurface), not just a line against a point.
>> Is this question not answerable? As a human I can determine it. I am
>> aware about the edge cases where a point is on the line, but in my case
>> this can't happen as the data comes from a correctly defined polygon
>> mosaic.
>>  From the lines of a polygon mosaic (directed lines node to node, no
>> double lines) I want to label what is left and what is right of a
>> polygon border. My theme is usage zones and I should label what is left
>> and right of the polygon border.
>> Andreas
>> Am 23.07.2013 16:48, schrieb Denis Rouzaud:
>>> Oops, here is the complete code:
>>> pointGeom << ST_Intersection( ST_MakeLine(
>>>               ST_MakePoint(ST_XMin(lineGeom), ST_Y(pointGeom)),
>>>               ST_MakePoint(ST_XMax(lineGeom), ST_Y(pointGeom))
>>>                            ), lineGeom
>>> On 07/23/2013 04:31 PM, Denis Rouzaud wrote:
>>>> Hi Andreas,
>>>> Do you mean you want to test to a segment?
>>>> Because, I can't see a true answer for a line.
>>>> If you want to do test to a segment, it should do the job to test if
>>>> the intersection with the horizontal line (dy=0) over your point and
>>>> your input line is on the left/right to your point.
>>>> So, maybe test:
>>>> You have to handle the case where your segment is horizontal, but then
>>>> a simple test with ST_Xmin/max should be enough.
>>>> Cheers,
>>>> Denis
>>>> On 07/23/2013 03:54 PM, Andreas Neumann wrote:
>>>>> Hi,
>>>>> I want to test a point if it is left-of or right-of a given
>>>>> LINESTRING.
>>>>> I found the << >> and &< &> but they do not behave like I expected.
>>>>> Perhaps it is because they only test on the bounding box level and not
>>>>> on the real geometry?
>>>>> Is there a left/right of test available on the geometry instead of the
>>>>> bounding box?
>>>>> Thank you,
>>>>> Andreas
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
