[postgis-users] Comparing St_Distance() with Google API
Morten Sickel morten at sickel.net
Wed Jul 24 04:26:17 PDT 2013
If you look into the json google produces, you should see that the start-
and endpoints are identical - and they are neither equal to neigher your
start- nor endpoint I would guess there are some rounding going on
somewhere - that the google api just is not able to distinguish between
points so close together.
Morten
James David Smith skrev:
> Hi there everyone,
> I've been messing about using the Google Directions API thing
> recently, and came across some odd results. Code to demonstrate is
> below.
> Essentially the distance between two points using PostGIS is 18
> metres, yet when I translate the points to Lat/Long and then stick
> them in the Google API the distance comes out as 1 metre.
> Does anyone have any thoughts on this?
> Thanks
> James
> -- Calculate a distance between two points using SRID 27700 (OSGB36):
> SELECT St_Distance(
> St_SetSRID(ST_makePoint(531058, 178463), 27700) ,
> St_SetSRID(ST_makePoint(531041, 178455), 27700)
> RESULT = 18.7882942280559  (I presume metres)
> -- Now calculte a distance between two points using SRID 4326 (WGS84):
> SELECT St_Distance(
> St_Transform(St_SetSRID(ST_makePoint(531058, 178463), 27700), 4326),
> St_Transform(St_SetSRID(ST_makePoint(531041, 178455), 27700), 4326)
> RESULT = 0.000256838311729703 (I presume degrees)
> -- Now calculate the distance using the Google Directions API using
> the Lat/Lon values:
> http://maps.googleapis.com/maps/api/directions/json?origin=51.4899343224464%20-0.113689479559085&destination=51.4898663658699%20-0.113937164484113&mode=walking&sensor=false&units=metric
> RESULT = "1 m"
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
