[postgis-users] PostGIS 2.02 view problem
karsten
karsten at terragis.net
Wed Jul 24 09:55:49 PDT 2013
Yes the view does have the gid (I did not include all the fields of the view
and stupidly forgit to t list the gid field in the email) below. I tried to
use a different colum as unique key and select it AS gid instead which did
not work (same error), then I added a new unique id using
nextval('myloc_loc_gid_seq'::regclass) AS gid (and omitted the old one),
still same error.
what else should, itry - running out of ideas
Cheers
Karsten
_____
From: Richard Greenwood [mailto:richard.greenwood at gmail.com]
Sent: Wednesday, July 24, 2013 07:05 AM
To: karsten at terragis.net; PostGIS Users Discussion
Cc: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS 2.02 view problem
In your map file you have "using unique gid". Are you sure that there is a
"gid" column in your view?
Rich
On Wed, Jul 24, 2013 at 3:35 AM, karsten <karsten at terragis.net> wrote:
Hi all,
I am trying to use a b view in Postgis 2.0.2 ("POSTGIS="2.0.2 r10789"
GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0,
released 2013/04/24" LIBXML="2.8.0" LIBJSON="UNKNOWN" TOPOLOGY RASTER")
for display via MapServer 6.2
I am getting an this error from MapServer:
Failed to draw layer named 'members'.
msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
column "COUNT" does not exist
LINE 1: select
"COUNT",encode(ST_AsBinary(ST_Force_2D("geom"),'NDR&
#39;).
I have no idea why a count is needed here or where this field is coming from
...seems that the regular table have no issue with this.
My VIEW public.geometry_columns shows these values for the view:
"xy";"xy";"myloc";"geom";2;4269;"POINT"
What can I do to fix this in Postgis ?
See below for view details
Cheers
Karsten
Terra GIS LTD
-- View:
CREATE OR REPLACE VIEW xy.test AS
SELECT xy.census_city_id, st_centroid(places.geom)::geometry(Point,4269) AS
geom, places.name
FROM myschema.xy,myschema.places
WHERE xy.census_city_id = places.geoid::integer;
ALTER TABLE myschema.xy_loc
OWNER TO myuser;
in mapfile:
DATA "geom from (select * from myschema.xy) as temp using unique gid using
SRID=4269"
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Richard Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130724/bc693ad6/attachment-0001.html>
