[postgis-users] PG_Dump PG_Restore and Topology
Christophe Vergon christophevergon-girtec at orange.fr
Fri Jul 26 00:17:45 PDT 2013
Sandro Santilli a écrit :
> Did you create the topology extension in the target database prior to
> load the data with postgis_restore.pl ?
We create database with : CREATE DATABASE databasename
TEMPLATE=template_postgis_20
> Did the postgis_restore.pl give you any error string to learn from ?
No error string returned from the postgis_restore.pl
We solved the pb with adding manually the rows in topology.topology, but
it's not an industrial way of work ;)
Christophe
