[postgis-users] Querying Multiple Rasters
Jayson Gallardo jaysontrades at gmail.com
Tue Jul 30 07:20:46 PDT 2013
Quick follow up question to my situation... I recently loaded 3m resolution
NED for Iowa. I have them loaded to one table per source tile, and have
them inheriting from the parent table that the Arkansas NED is inheriting
from. Ever since, however, my database seems to be running pretty slow.
I've run a full vacuum on the data, and there are constraints on each
table.
How can I be sure that when I query the parent database that it's not
querying every single table?
On Tue, Jul 23, 2013 at 3:14 PM, Bborie Park <dustymugs at gmail.com> wrote:
> I'm just glad to help. Feel free to post your experience, feedback, issues
> and/or wishes on the mailing-list.
> -bborie
> On Tue, Jul 23, 2013 at 1:10 PM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
>> Oh, okay. Yeah you're right about it taking time. I wrote a python script
>> to generate the raster2pgsql call with the appropriate table name, so I can
>> just let it run while I do other things. I really appreciate your help on
>> this. I googled your name and I see you're a pretty busy person, so I'm
>> glad you're taking the time to answer my questions.
>> On Tue, Jul 23, 2013 at 3:05 PM, Bborie Park <dustymugs at gmail.com> wrote:
>>> No. I'm suggesting it later as it does take time and separates
>>> operations. Get everything imported first and then add constraints.
>>> Having said that, you can do it all at once if so desired... just
>>> preference depending on volume of import data.
>>> -bborie
>>> On Tue, Jul 23, 2013 at 1:02 PM, Jayson Gallardo <jaysontrades at gmail.com
>>> > wrote:
>>>> Okay, is there a specific reason why? As your link states: "
>>>> raster2pgsql loader uses this function to register raster tables". Are
>>>> you saying I should specify constraints that will be similar across all
>>>> tables?
>>>> On Tue, Jul 23, 2013 at 2:53 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>> I'd suggest adding constraints after the fact through SQL instead of
>>>>> letting raster2pgsql do it.
>>>>> http://www.postgis.net/docs/manual-2.0/RT_AddRasterConstraints.html
>>>>> -bborie
>>>>> On Tue, Jul 23, 2013 at 12:51 PM, Jayson Gallardo <
>>>>> jaysontrades at gmail.com> wrote:
>>>>>> So based on the link you provided, and what else I've gathered, I
>>>>>> first create a parent table:
>>>>>>  CREATE TABLE dem_elevation
>>>>>>   rid integer NOT NULL PRIMARY KEY
>>>>>>   rast raster,
>>>>>>  Then I run raster2pgsql on all the downloaded elevation data,
>>>>>> sending each input tile to its own table, ie. dem_elevation_n36w091. Then
>>>>>> alter table to inherit from parent:
>>>>>> ALTER TABLE dem_elevation_n36w091 INHERIT dem_elevation;
>>>>>> With raster2pgsql taking care of setting the constraints for each
>>>>>> table. Now, I can just query the parent table dem_elevation to get what I
>>>>>> need?
>>>>>> On Tue, Jul 23, 2013 at 2:33 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>>> I use the USGS NED 10 meter for California with one table for each
>>>>>>> input raster. In the partitioned table scheme, data tables inherit from a
>>>>>>> template (parent) table. Queries run on the parent table access the
>>>>>>> inherited tables.
>>>>>>> -bborie
>>>>>>> On Tue, Jul 23, 2013 at 11:56 AM, Jayson Gallardo <
>>>>>>>> Yes, it's usgs ned. And I initially went with one table for each
>>>>>>>> input tile, but I didn't know how to join (or union) them together for my
>>>>>>>> query.
>>>>>>>>  On Jul 23, 2013 1:14 PM, "Bborie Park" <dustymugs at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Can you describe your elevation dataset? Is it USGS NED? At which
>>>>>>>>> resolution (10 meter, 3 meter?)?
>>>>>>>>> As for table partitioning...
>>>>>>>>> http://www.postgresql.org/docs/9.0/static/ddl-partitioning.html
>>>>>>>>> You'll probably partition spatially, though an easy solution is to
>>>>>>>>> have a table for each input raster file.
>>>>>>>>> -bborie
>>>>>>>>> On Tue, Jul 23, 2013 at 11:05 AM, Jayson Gallardo <
>>>>>>>>>> Thanks for responding. Could you outline how I would go about
>>>>>>>>>> doing a partitioned table structure? My only concern with tile size is
>>>>>>>>>> processing time. Most of my queries will involve areas of less than 1 mi^2,
>>>>>>>>>> and I would clip the data into that shape. I just don't know where to
>>>>>>>>>> start! There's not too many resources online/print dealing with postgis
>>>>>>>>>> rasters in detail.
>>>>>>>>>> On Tue, Jul 23, 2013 at 12:57 PM, Bborie Park <
>>>>>>>>>>> You may not need to drop all the constraints when adding
>>>>>>>>>>> additional data to the table. You most likely will need to drop is the
>>>>>>>>>>> maximum extent constraint. Assuming the input rasters have the same scale,
>>>>>>>>>>> skew and SRID as that found in the table, you don't need to drop those
>>>>>>>>>>> corresponding constraints.
>>>>>>>>>>> If you're going to do the continental US at a fine resolution
>>>>>>>>>>> (e.g. 1 meter), you do NOT want to put all the rasters in one table. You'll
>>>>>>>>>>> want to use a partitioned table structure and should consider a bigger tile
>>>>>>>>>>> size (depending on your hardware).
>>>>>>>>>>> -bborie
>>>>>>>>>>> On Tue, Jul 23, 2013 at 10:43 AM, Jayson Gallardo <
>>>>>>>>>>>> I've looked and looked, but I have not been able to find an
>>>>>>>>>>>> answer to my question. I have downloaded elevation data for the state of
>>>>>>>>>>>> Arkansas (in the form of multiple tiles), and used raster2pgsql to upload
>>>>>>>>>>>> it into a single table:
>>>>>>>>>>>> raster2pgsql -I -C -e -F -t 50x50 -l 2,4 n*/grdn*
>>>>>>>>>>>> public.dem_elevation | psql -U postgres -d testdb -h localhost -p 5432
>>>>>>>>>>>> I did this because I didn't know how to pull the data if they
>>>>>>>>>>>> were in separate tables. Now, however I would like to add elevation data
>>>>>>>>>>>> for other areas. I tried to just add it to the current table, but that
>>>>>>>>>>>> required dropping the constraints which for such a huge amount of data
>>>>>>>>>>>> seems to take a long time (I let it run for 24+ hours and it didn't
>>>>>>>>>>>> finish). So, my question is, if I load all my rasters as individual tables,
>>>>>>>>>>>> how could I run something similar to this query on them all (from a python
>>>>>>>>>>>> script):
>>>>>>>>>>>> SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
>>>>>>>>>>>> ST_GeomFromText(WKT,900913)),'GTiff') FROM "dem_elevation" WHERE
>>>>>>>>>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(WKT,900913),4269))
>>>>>>>>>>>> My goal, if it's not obvious, is to clip elevation data and
>>>>>>>>>>>> export it to a GTiff format and perform some operations on that raster
>>>>>>>>>>>> data. Eventually, I would like to put the whole continental US elevation
>>>>>>>>>>>> data into my database, so I need to be able to do so, while still being
>>>>>>>>>>>> able to query them based on an area of interest the user selects from a
>>>>>>>>>>>> map. I started working with PostGIS and Mapserver last month, so please
>>>>>>>>>>>> forgive my ignorance on such topics. Thanks in advance
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>>> postgis-users at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130730/87f6f34f/attachment.html>
