[postgis-users] Querying Multiple Rasters
Jayson Gallardo
jaysontrades at gmail.com
Tue Jul 30 09:35:11 PDT 2013
I suppose I could do that in my script. How should I go about that? My
process is as follows:
- User selects area of interest on a map (openlayers)
- User clicks submit, and python script is called with the WKT passed as
an argument
- Python script queries the database, which then outputs the raster
- Raster is processed through a library
- Processed raster is displayed as an overlay on the map
On Tue, Jul 30, 2013 at 11:31 AM, Bborie Park <dustymugs at gmail.com> wrote:
> Are you able to transform the wkt before passing it to the sql?
> Partitioning only works on constant values, not values that need
> processing, e.g. ST_Transform(ST_GeomFromText(\'%s\',%i),%i)).
> -bborie
> On Tue, Jul 30, 2013 at 9:25 AM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
>> Here's the constraints:
>> CONSTRAINT dem_elevation_n33w092_pkey PRIMARY KEY (rid ),
>> CONSTRAINT enforce_height_rast CHECK (st_height(rast) = 100),
>> CONSTRAINT enforce_max_extent_rast CHECK
>> (st_coveredby(st_convexhull(rast), '*...truncated...*'::geometry)),
>> CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) = 1),
>> CONSTRAINT enforce_out_db_rast CHECK (_raster_constraint_out_db(rast) =
>> '{f}'::boolean[]),
>> CONSTRAINT enforce_pixel_types_rast CHECK
>> (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
>> CONSTRAINT enforce_same_alignment_rast CHECK (st_samealignment(rast, '*
>> ...truncated...*'::raster)),
>> CONSTRAINT enforce_scalex_rast CHECK (st_scalex(rast)::numeric(16,10) =
>> 0.000092592592593::numeric(16,10)),
>> CONSTRAINT enforce_scaley_rast CHECK (st_scaley(rast)::numeric(16,10) =
>> (-0.000092592592593)::numeric(16,10)),
>> CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) = 4269),
>> CONSTRAINT enforce_width_rast CHECK (st_width(rast) = 100)
>> and my python script:
>> wkt = sys.argv[1] # Polygon shape in WKT format
>> raster_type = 'GTiff'
>> table_name = 'dem_elevation'
>> map_srs = 900913
>> table_srs = 4269
>> sql_text = 'SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
>> ST_GeomFromText(\'%s\',%i)),\'%s\') FROM "%s" WHERE ST_Intersects(rast,
>> ST_Transform(ST_GeomFromText(\'%s\',%i),%i))' % (wkt, map_srs,
>> raster_type, table_name, wkt, map_srs, table_srs)
>> On Tue, Jul 30, 2013 at 11:12 AM, Bborie Park <dustymugs at gmail.com>wrote:
>>> Jayson,
>>> Can you share one of the queries? Also, what check constraints are you
>>> using?
>>> -bborie
>>> On Tue, Jul 30, 2013 at 7:49 AM, Jayson Gallardo <jaysontrades at gmail.com
>>> > wrote:
>>>> So, I used Explain on my SELECT statement, and whether
>>>> constraint_exclusion is on or off, it seems to spit out the same number of
>>>> rows in the query plan. Is there something I need to do for my table
>>>> constraints so that it doesn't do a check on every table I have loaded?
>>>> On Tue, Jul 30, 2013 at 9:20 AM, Jayson Gallardo <
>>>> jaysontrades at gmail.com> wrote:
>>>>> Quick follow up question to my situation... I recently loaded 3m
>>>>> resolution NED for Iowa. I have them loaded to one table per source tile,
>>>>> and have them inheriting from the parent table that the Arkansas NED is
>>>>> inheriting from. Ever since, however, my database seems to be running
>>>>> pretty slow. I've run a full vacuum on the data, and there are constraints
>>>>> on each table.
>>>>> How can I be sure that when I query the parent database that it's not
>>>>> querying every single table?
>>>>> On Tue, Jul 23, 2013 at 3:14 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>> I'm just glad to help. Feel free to post your experience, feedback,
>>>>>> issues and/or wishes on the mailing-list.
>>>>>> -bborie
>>>>>> On Tue, Jul 23, 2013 at 1:10 PM, Jayson Gallardo <
>>>>>>> Oh, okay. Yeah you're right about it taking time. I wrote a python
>>>>>>> script to generate the raster2pgsql call with the appropriate table name,
>>>>>>> so I can just let it run while I do other things. I really appreciate your
>>>>>>> help on this. I googled your name and I see you're a pretty busy person, so
>>>>>>> I'm glad you're taking the time to answer my questions.
>>>>>>> On Tue, Jul 23, 2013 at 3:05 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>>>> No. I'm suggesting it later as it does take time and separates
>>>>>>>> operations. Get everything imported first and then add constraints.
>>>>>>>> Having said that, you can do it all at once if so desired... just
>>>>>>>> preference depending on volume of import data.
>>>>>>>> -bborie
>>>>>>>> On Tue, Jul 23, 2013 at 1:02 PM, Jayson Gallardo <
>>>>>>>>> Okay, is there a specific reason why? As your link states: "
>>>>>>>>> raster2pgsql loader uses this function to register raster
>>>>>>>>> tables". Are you saying I should specify constraints that will be similar
>>>>>>>>> across all tables?
>>>>>>>>> On Tue, Jul 23, 2013 at 2:53 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>>>>>>>> I'd suggest adding constraints after the fact through SQL instead
>>>>>>>>>> of letting raster2pgsql do it.
>>>>>>>>>> http://www.postgis.net/docs/manual-2.0/RT_AddRasterConstraints.html
>>>>>>>>>> -bborie
>>>>>>>>>> On Tue, Jul 23, 2013 at 12:51 PM, Jayson Gallardo <
>>>>>>>>>>> So based on the link you provided, and what else I've gathered,
>>>>>>>>>>> I first create a parent table:
>>>>>>>>>>> CREATE TABLE dem_elevation
>>>>>>>>>>> rid integer NOT NULL PRIMARY KEY
>>>>>>>>>>> rast raster,
>>>>>>>>>>> Then I run raster2pgsql on all the downloaded elevation data,
>>>>>>>>>>> sending each input tile to its own table, ie. dem_elevation_n36w091. Then
>>>>>>>>>>> alter table to inherit from parent:
>>>>>>>>>>> ALTER TABLE dem_elevation_n36w091 INHERIT dem_elevation;
>>>>>>>>>>> With raster2pgsql taking care of setting the constraints for
>>>>>>>>>>> each table. Now, I can just query the parent table dem_elevation to get
>>>>>>>>>>> what I need?
>>>>>>>>>>> On Tue, Jul 23, 2013 at 2:33 PM, Bborie Park <
>>>>>>>>>>>> I use the USGS NED 10 meter for California with one table for
>>>>>>>>>>>> each input raster. In the partitioned table scheme, data tables inherit
>>>>>>>>>>>> from a template (parent) table. Queries run on the parent table access the
>>>>>>>>>>>> inherited tables.
>>>>>>>>>>>> -bborie
>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:56 AM, Jayson Gallardo <
>>>>>>>>>>>>> Yes, it's usgs ned. And I initially went with one table for
>>>>>>>>>>>>> each input tile, but I didn't know how to join (or union) them together for
>>>>>>>>>>>>> my query.
>>>>>>>>>>>>> On Jul 23, 2013 1:14 PM, "Bborie Park" <dustymugs at gmail.com>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Can you describe your elevation dataset? Is it USGS NED? At
>>>>>>>>>>>>>> which resolution (10 meter, 3 meter?)?
>>>>>>>>>>>>>> As for table partitioning...
>>>>>>>>>>>>>> http://www.postgresql.org/docs/9.0/static/ddl-partitioning.html
>>>>>>>>>>>>>> You'll probably partition spatially, though an easy solution
>>>>>>>>>>>>>> is to have a table for each input raster file.
>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 11:05 AM, Jayson Gallardo <
>>>>>>>>>>>>>>> Thanks for responding. Could you outline how I would go
>>>>>>>>>>>>>>> about doing a partitioned table structure? My only concern with tile size
>>>>>>>>>>>>>>> is processing time. Most of my queries will involve areas of less than 1
>>>>>>>>>>>>>>> mi^2, and I would clip the data into that shape. I just don't know where to
>>>>>>>>>>>>>>> start! There's not too many resources online/print dealing with postgis
>>>>>>>>>>>>>>> rasters in detail.
>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 12:57 PM, Bborie Park <
>>>>>>>>>>>>>>>> You may not need to drop all the constraints when adding
>>>>>>>>>>>>>>>> additional data to the table. You most likely will need to drop is the
>>>>>>>>>>>>>>>> maximum extent constraint. Assuming the input rasters have the same scale,
>>>>>>>>>>>>>>>> skew and SRID as that found in the table, you don't need to drop those
>>>>>>>>>>>>>>>> corresponding constraints.
>>>>>>>>>>>>>>>> If you're going to do the continental US at a fine
>>>>>>>>>>>>>>>> resolution (e.g. 1 meter), you do NOT want to put all the rasters in one
>>>>>>>>>>>>>>>> table. You'll want to use a partitioned table structure and should consider
>>>>>>>>>>>>>>>> a bigger tile size (depending on your hardware).
>>>>>>>>>>>>>>>> -bborie
>>>>>>>>>>>>>>>> On Tue, Jul 23, 2013 at 10:43 AM, Jayson Gallardo <
>>>>>>>>>>>>>>>>> I've looked and looked, but I have not been able to find
>>>>>>>>>>>>>>>>> an answer to my question. I have downloaded elevation data for the state of
>>>>>>>>>>>>>>>>> Arkansas (in the form of multiple tiles), and used raster2pgsql to upload
>>>>>>>>>>>>>>>>> it into a single table:
>>>>>>>>>>>>>>>>> raster2pgsql -I -C -e -F -t 50x50 -l 2,4 n*/grdn*
>>>>>>>>>>>>>>>>> public.dem_elevation | psql -U postgres -d testdb -h localhost -p 5432
>>>>>>>>>>>>>>>>> I did this because I didn't know how to pull the data if
>>>>>>>>>>>>>>>>> they were in separate tables. Now, however I would like to add elevation
>>>>>>>>>>>>>>>>> data for other areas. I tried to just add it to the current table, but that
>>>>>>>>>>>>>>>>> required dropping the constraints which for such a huge amount of data
>>>>>>>>>>>>>>>>> seems to take a long time (I let it run for 24+ hours and it didn't
>>>>>>>>>>>>>>>>> finish). So, my question is, if I load all my rasters as individual tables,
>>>>>>>>>>>>>>>>> how could I run something similar to this query on them all (from a python
>>>>>>>>>>>>>>>>> script):
>>>>>>>>>>>>>>>>> ST_GeomFromText(WKT,900913)),'GTiff') FROM "dem_elevation" WHERE
>>>>>>>>>>>>>>>>> ST_Intersects(rast, ST_Transform(ST_GeomFromText(WKT,900913),4269))
>>>>>>>>>>>>>>>>> My goal, if it's not obvious, is to clip elevation data
>>>>>>>>>>>>>>>>> and export it to a GTiff format and perform some operations on that raster
>>>>>>>>>>>>>>>>> data. Eventually, I would like to put the whole continental US elevation
>>>>>>>>>>>>>>>>> data into my database, so I need to be able to do so, while still being
>>>>>>>>>>>>>>>>> able to query them based on an area of interest the user selects from a
>>>>>>>>>>>>>>>>> map. I started working with PostGIS and Mapserver last month, so please
>>>>>>>>>>>>>>>>> forgive my ignorance on such topics. Thanks in advance
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>>>>>>>> postgis-users at lists.osgeo.org
>>>>>>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130730/e4bf3501/attachment.html>
