[postgis-users] ST_AsPNG is problematic in Java
Ahmet Temiz ahmettemiz88 at gmail.com
Mon Jun 17 06:04:03 PDT 2013
hello
postgresql (9.2.2)
postgresql-jdbc 9.2
here is the result of SELECT postgis_full_version();
 POSTGIS="2.1.0SVN r10952" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.8.0" RASTER
thank you
On Mon, Jun 17, 2013 at 3:45 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Which JDBC driver are you using and which PostgreSQL version.  You might
> be affected by the escape/hex change in 9.0
> detailed here:
> http://postgis.net/docs/manual-2.0/PostGIS_FAQ.html#id338804
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Ahmet Temiz
> *Sent:* Monday, June 17, 2013 8:32 AM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] ST_AsPNG is problematic in Java
> hello
> I am dealing with java-jpa2-postgis(raster)
> I tried to get an image from postgis(raster) as:
>  List list_rast = session.createSQLQuery("SELECT ST_AsPNG(rast) As
> rastpng  FROM geoslp5 where rid=184 ;").list();
> and converting object to byte[]
> and
> with usual java process
> ByteArrayOutputStream bos = new ByteArrayOutputStream();
> bytes = bos.toByteArray ();
> But resulting image file(png) is defective ?
> What may the probable problems ?
> Do you have any recommendations ?
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Planlama ve Zarar Azaltma Dairesi Başkanlığı
> ________________________
> Ahmet Temiz
> Geological Eng.
> Information Systems - GIS Group
> Disaster and Emergency Management
> of Presidency
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130617/2a5acfe9/attachment.html>
