[postgis-users] ST_Union - Resulting SRID set to 0
Sandro Santilli
strk at keybit.net
Thu Jun 27 09:24:55 PDT 2013
On Thu, Jun 27, 2013 at 10:48:47AM -0400, Jason Greenlaw - NOAA Affiliate wrote:
> Hello all,
> I have a table with multipolygon geometry in EPSG:3857 (web mercator) that
> I'm trying to dissolve (grouping by a field) into another table using an
> aggregate call to ST_Union, but for some reason the SRID isn't carrying
> over (SRID gets set to zero). I've also tried calling ST_SetSRID on the
> result but that too results in SRID = 0.
> I'm fairly new to PostGIS - can anyone point out my mistake?
> Here's the query I'm using:
> CREATE TABLE ds1_dissolved AS SELECT
> code,ST_Union(ST_SnapToGrid(wkb_geometry, 0.0001)) AS wkb_geometry FROM ds1
> WHERE ST_IsValid(wkb_geometry) GROUP BY code;
> or, with an additional call to ST_SetSRID:
> code,ST_SetSRID(ST_Union(ST_SnapToGrid(wkb_geometry, 0.0001)), 3857) AS
> wkb_geometry FROM ds1 WHERE ST_IsValid(wkb_geometry) GROUP BY code;
> Both methods seem to work except for the SRID being set to zero as reported
> in geometry_columns:
> # SELECT * FROM public.geometry_columns WHERE
> f_table_name='ds1_dissolved';
> f_table_catalog | f_table_schema | f_table_name |
> f_geometry_column | coord_dimension | srid | type
> dbname | schemaname | ds1_dissolved | wkb_geometry |
> 2 | 0 | GEOMETRY
> (1 row)
> Describing the original table using \d reports the type of the
> 'wkb_geometry' field as: geometry(MultiPolygon,3857)
> Describing the dissolved table using \d reports the type of the
> Any help greatly appreciated!
The SRID of your geometries is NOT zero, only the _type_ of your geometry
doesn't constraint a SRID. You can check the SRID of your geometries with
a query like this:
SELECT distinct ST_Srid(wkb_geometry) from schemaname.ds1_dissolved;
If you want to _constraint_ a SRID you'll have to cast it
in the "CREATE TABLE AS" query:
CREATE TABLE ds1_dissolved AS SELECT code,
ST_Union(ST_SnapToGrid(wkb_geometry, 0.0001))::geometry(geometry,3857)
AS wkb_geometry
Similarly, you could constraint a type (instead of the generic "geometry),
althought ST_Union may return unexpected types.
--strk;
