[postgis-users] PostGIS 2.0.3 released
Jerry Carter
jerry at jerrycarter.org
Fri Mar 1 08:36:35 PST 2013
Minor question on the upgrade process and PostgreSQL extensions.
When I built from source and upon the completion of 'make install', PostgreSQL reported [1] that version 2.0.3 was present BEFORE issuing the ALTER EXTENSION commands as advised in section 2.9.1.2 of the documentation. Are the 'ALTER EXTENSION' commands really necessary? If not, perhaps the documentation might suggest checking the version first. If so, a warning in the documentation that the reported version doesn't match the installed version seems appropriate.
Thanks.
-=- Jerry
[1] SELECT "name",default_version,installed_version FROM pg_available_extensions WHERE "name" ILIKE 'postgis%'
On Mar 1, 2013, at 11:07 AM, Sandro Santilli <strk at keybit.net> wrote:
> The third bugfix release in the 2.0 series of PostGIS is out.
> Tarball: http://download.osgeo.org/postgis/source/postgis-2.0.3.tar.gz
> (md5sum 23dce6a04992d5fdd07593b6bccf3a7d)
> Changes: http://svn.osgeo.org/postgis/tags/2.0.3/NEWS
> Upgrade is recommended.
> Best served with a bottle of GEOS 3.3.8:
> http://lists.osgeo.org/pipermail/geos-devel/2013-February/006241.html
> Enjoy!
> The PostGIS Developers Team
> http://postgis.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
