[postgis-users] design problem
Stephen V. Mather svm at clevelandmetroparks.com
Fri Mar 1 14:09:10 PST 2013
Ah, partitioning seems like it should work, but if you're doing it for the sake of query optimization, you would have to write some funky (and technically non-spatial or a mix of spatial and non-spatial) queries to ensure the partitioning accomplishes anything.
See the comments from Regina on Paul Ramsey's post here:
http://blog.cleverelephant.ca/2011/02/spatial-partitioning-in-postgis.html
AFAIK, no work has gone into enabling the range functions used in partitioning to leverage spatial partitioning.  It would be nice for large datasets though... .
BTW, like others have indicated, it would help to have for excising and recreating sections of the dataset, in the case of datasets that change a lot and are really big... .
Hope this helps,
Best,
Steve
  Stephen V. Mather
GIS Manager
(216) 635-3243 (Work)
________________________________________
From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] on behalf of Denise Janson [denise.j.ferreira at gmail.com]
Sent: Friday, March 01, 2013 4:11 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] design problem
I have an application that is going to receive lots of georeferenced files
every day. Each file has information of several points. Probably in few
years my application will have a Tera of points information stored.
I think I can do this design  in two ways:
1. Two tables, one of “uploaded_files”, and another of “points” (one
uploadedFile to N points). And I'll have to partition the points table,
maybe by month …
2. Or I can create one table per file, having thousands of tables in few
years.
Which case is better for my application?  Is there any better way to do
this?
View this message in context: http://postgis.17.n6.nabble.com/design-problem-tp5002778.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
