[postgis-users] CTE example
Patrick Browne patrickcbbrowne at gmail.com
Tue Mar 5 12:50:46 PST 2013
Shira,
That worked using SRID=4269.
Thanks you very much,
Pat
On Tue, Mar 5, 2013 at 8:07 PM, Shira Bezalel <shira at sfei.org> wrote:
> Hi Patrick,
> I ran into this same problem not too long ago. I got it to work with minor
> changes in the syntax of the 3rd CTE before the final select statement like
> so:
> grid AS -- Define CTE to store our grid that uses usext and grid_dim
> (SELECT ST_SetSRID(ST_MakeBox2d(ST_Point(xmin + (a - 1)*g_width, ymin +
> (b-1)*g_height),
> ST_Point(xmin + a*g_width, ymin + b*g_height)), 3310) As grid_geom
> FROM
> (SELECT generate_series(1,x_gridcnt) as a FROM usext) As x CROSS JOIN
> (SELECT generate_series(1,y_gridcnt) as b FROM usext) As y CROSS JOIN
> grid_dim)
> Of course, I think Regina/Leo are probably the one to confirm if my
> changes are OK.
> Shira
> Shira Bezalel
> Database & Systems Manager
> San Francisco Estuary Institute
> 4911 Central Ave
> Richmond CA 94804
> Ph: 510-746-7304
> Fax: 510-746-7300
> ----- Original Message -----
> From: "Patrick Browne" <patrickcbbrowne at gmail.com>
> To: postgis-users at lists.osgeo.org
> Sent: Tuesday, March 5, 2013 11:52:57 AM
> Subject: [postgis-users] CTE example
> I am trying to run the CTE example on slide 22 from
> http://www.postgis.us/downloads/oscon2009_PostGISTips.pdf
> When I paste the example into the SQL-shell I get the following error:
> ERROR: operator does not exist: record - integer LINE 14: ... x, y,
> ST_SetSRID(ST_MakeBox2d(ST_Point(xmin + (x - 1)*g_wid... HINT: No operator
> matches the given name and argument type(s). You might need to add explicit
> type casts
> I am using POSTGIS 1.4.1 with Postgres 8.4 I used the data that accompany
> the slides.
> Any advice will be much appreciated.
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130305/8f06862e/attachment.html>
