[postgis-users] null to zero
Francois Hugues
hugues.francois at irstea.fr
Tue Mar 19 11:42:08 PDT 2013
Hello,
I'm not sure to understand your problem but maybe st_numgeometries is not the right function to use since it counts geometries. Within a multipolygon.
Maybe am i wrong but why don't you use count() like a similar problem suggested it recently ?
Select foo1.id, coalesce(count(*), 0)
>From foo1
Left join foo.edge_data on st_intersects(foo1.five, foo.effet_data.geom)
Group by foo1.id
Hugues
Bob Pawley <rjpawley at shaw.ca> a écrit :
Hi
I am attempting to establish the number of geometries intersecting various polygons and relating the number of geometries to the id of each polygon.
The below works for a single known polygon.
select coalesce (sum(st_numgeometries(foo.edge_data.geom)), 0)
from foo1, foo.edge_data
where st_intersects(foo.edge_data.geom, foo1.five)
and foo1.id = 58
(returns 0)
However I would like to select all the polygons and choose only those intersected by zero or one geometry.
But in the following, as soon as I use the” group by” clause, does not return the coalesced null values, it only returns geometries numbering 1 or more.
select coalesce (sum(st_numgeometries(foo.edge_data.geom)), 0), foo1.id
and foo1.id = foo1.id
group by foo1.id
Is there any way of reworking this to obtain polygon ids with null valued intersections??
Bob
