[postgis-users] null to zero
Bob Pawley
rjpawley at shaw.ca
Wed Mar 20 08:29:40 PDT 2013
Thanks Francois
Your suggestion worked.
It really helps for someone to look at the trees while I am only able to see
the forest.
Bob
-----Original Message-----
Sent: Tuesday, March 19, 2013 12:06 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] null to zero
Maybe, you will have to use count(foo.edge_data.geom) instead of count(*) as
Tom underlined it before.
Hugues
Francois Hugues <hugues.francois at irstea.fr> a écrit :
Hello,
I'm not sure to understand your problem but maybe st_numgeometries is not
the right function to use since it counts geometries. Within a multipolygon.
Maybe am i wrong but why don't you use count() like a similar problem
suggested it recently ?
Select foo1.id, coalesce(count(*), 0)
>From foo1
Left join foo.edge_data on st_intersects(foo1.five, foo.effet_data.geom)
Group by foo1.id
Hugues
Bob Pawley <rjpawley at shaw.ca> a écrit :
Hi
I am attempting to establish the number of geometries intersecting various
polygons and relating the number of geometries to the id of each polygon.
The below works for a single known polygon.
select coalesce (sum(st_numgeometries(foo.edge_data.geom)), 0)
from foo1, foo.edge_data
where st_intersects(foo.edge_data.geom, foo1.five)
and foo1.id = 58
(returns 0)
However I would like to select all the polygons and choose only those
intersected by zero or one geometry.
But in the following, as soon as I use the” group by” clause, does not
return the coalesced null values, it only returns geometries numbering 1 or
more.
select coalesce (sum(st_numgeometries(foo.edge_data.geom)), 0), foo1.id
and foo1.id = foo1.id
group by foo1.id
Is there any way of reworking this to obtain polygon ids with null valued
intersections??
Bob
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
