[postgis-users] srid, geometry type in spatial view
John Callahan
john.callahan at udel.edu
Thu Mar 21 12:28:32 PDT 2013
Apologize for the noise.
I found what I needed here:
http://gis.stackexchange.com/questions/35427/postgis-2-0-public-geometry-columns-view-does-not-contain-correct-info-for-vie
- John
On Thu, Mar 21, 2013 at 2:39 PM, John Callahan <john.callahan at udel.edu>wrote:
> Forgot to mention, we are currently running Postgres 9.0.7 with PostGIS
> 2.0.2 on Windows.
> - John
> On Thu, Mar 21, 2013 at 2:37 PM, John Callahan <john.callahan at udel.edu>wrote:
>> I have a few spatial tables that are POLYGON and MULTIPOLYGON as the
>> geometry type, each with between 1k and 10k features. They only a couple
>> of attributes and generally look good., and display in QGIS nicely. I also
>> have a separate (non-spatial) data table (called geodatatable) with about
>> 50 records that contains numerous attributes and is joined to the polygons
>> as follows
>> CREATE OR REPLACE VIEW public.geomapview AS
>> SELECT geomap.gid, geomap.unitcode, tab.name, tab.description,
>> tab.geologicunittype, tab.metadata, geomap.geom
>> FROM geomap
>> LEFT JOIN geodatatable tab ON geomap.unitcode::text =
>> tab.unitcode::text;
>> However. when I look at the geometry_columns view, the srid is listed as
>> 0 and the type is listed as GEOMETRY. Shouldn't they be the same as the
>> spatial table? Is there a way to manually fix this or something I can
>> check? Thanks for your help.
>> - John
>> John Callahan
>> Research Scientist
>> Delaware Geological Survey
>> University of Delaware
>> http://www.dgs.udel.edu
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130321/6193e137/attachment.html>
