[postgis-users] The "bow tie" error
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 21 14:06:59 PDT 2013
Francois,
Can you dump the polygons in the multiplyogon and create separate
records for them. So in you example graphic, you would end up with two
separate polygons the touch at a point. I think this would be OK for qgis.
-Steve W
On 3/21/2013 4:57 PM, Francois Hugues wrote:
> Hello,
> I have to deal with a dataset with a lot of errors. I ran a
> st_makevalid which seems to give me good results (all polygons then
> appear to be valid, closed and simple). But, when I open this table
> as a layer in qgis it still throws me a lot of errors. The image
> attached to this message provide you with an example and the error
> said : Le segment 0 de l'anneau 16 du polygone 6 est intersecté au
> segment 0 de l'anneau 1 du polygone 7 à 933828.8196, 6261164.472 (in
> english this may be something like : line 0 of ring 16 is intersected
> by line 0 of ring 1 of polygon 7 at point...).
> As the rings of the multipolygon share one point, I tried to dump it
> and then to union the rings to build a single polygon but I got a
> multipolygon back and still an error.
> The dataset have a lot of "bow ties" and it seems that st_makevalid
> change them to multipolygon but that do not correct all errors in
> qgis.
> Does anyone have an idea to find any solution ?
> Hugues
> Hugues FRANÇOIS
> hugues.francois at irstea.fr
> _______________________________________________ postgis-users mailing
> list postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
