[postgis-users] accuracy of coverage
Ivan Santiago
isantiago at ogp.pr.gov
Wed May 1 11:23:34 PDT 2013
Hello:
Out of curiosity, which are these geodetic problems of the 'google maps projection'?
Iván Santiago
GIS Specialist
Information Technologies
Office of Management and Budget
787.725.9420 x 2378
Calle Cruz 254
PO Box 9023228
San Juan, PR 00902-3228
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of b.j.kobben at utwente.nl
Sent: Wednesday, May 01, 2013 1:25 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] accuracy of coverage
Since Gmaps uses not the geographic positions (lat-lon), but the feared "google maps projection" which has many geodetic problems, I would trust the PG calculation. However, are you sure the 4000 in your SQL will be interpreted as meters, not as 4000 decimal degrees (in that case the point will certainly always be inside, of course)?
Barend
Barend Köbben
Senior Lecturer, ITC - University of Twente, Faculty of Geo-Information Science and Earth Observation PO Box 217, 7500AE Enschede (The Netherlands)
+31-(0)53 4874 253
FOSS4G 2013: Geo for All
Nottingham (UK), 17-21 Sep 2013
http://2013.foss4g.org
On 01-05-13 17:15, "Gold, Jack L (US SSA)" <jack.gold at baesystems.com>
wrote:
>I am trying to determine the accuracy of the ST_DWithin function. I
>have a position at 32.52550166, -84.96989441 and I want to know if it
>is within a projected circle of 4km radius centered on 32.5, -85.
>I am running the following query:
>SELECT "id","location", ST_AsText(location) as "text_position" FROM
>"positions" WHERE (ST_DWithin(location,
>ST_geographyFromText("SRID=4326;POINT(-85.0000035762821
>32.49999701976208)"), 4000.0))
>³location² is defined as a geography
>When I map this out, Google Maps shows the position report outside of
>the 4km ring as does my application, but the database is reporting that
>the position is within the 4km range of the ring. I suspect the error
>is small, but I¹m wondering where it lies.
>Any ideas?
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
