[postgis-users] How to improve query with repeated spatial joinquery
Alexandre Neto
senhor.neto at gmail.com
Fri May 3 03:55:59 PDT 2013
Hi!
Thanks for the hint, I will try to use it and to understand what it is
doing.
Alexandre Neto
On Fri, May 3, 2013 at 11:32 AM, Hugues François
<hugues.francois at irstea.fr>wrote:
> Hello,
> I think over() can help you. You should try something like the query below
> select b.gid, volume / sum(volume) over(partition by p.gid) asvol_per,
> p.bgrill as bgrill, b.geom
> from buildings as b,
> join stat_parcels as p on st_contains(p.geom, st_centroid(b.geom))
> Hugues.
> Hugues FRANÇOIS****
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Alexandre Neto
> *Sent:* Friday, May 03, 2013 12:25 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] How to improve query with repeated spatial
> joinquery
> Hello all,
> My goal is to calculate for each building it's volume
> percentage relatively to the total buildings volume inside the statistical
> parcel he is in.
> I have written the SQL code below (that works), but I think it might be
> improved, since I see repeated proceedings in it.
> I would greatly appreciate if someone give me some advice about it.
> Thanks,
> Alexandre Neto
> SELECT
> b.gid,
> b.volume / t.total_volume as vol_per,
> b.geom,
> p.bgri11 as bgri11,
> FROM
> buildings as b,
> stat_parcels as p,
> (SELECT
> sum(b.volume) as total_volume,
> p.bgri11 as bgri11
> FROM
> buildings as b,
> stat_parcels as p
> WHERE
> ST_CONTAINS(p.geom, St_centroid(b.geom))
> GROUP BY
> p.bgri11) as t
> WHERE
> ST_CONTAINS(g.geom, St_centroid(f.geom))
> AND p.bgri11 = t.bgri11;
> My tables look like this:
> CREATE TABLE buildings
> gid serial NOT NULL,
> volume double precision,
> geom geometry(MultiPolygon,27493),
> CONSTRAINT edificios_habitacao_pkey PRIMARY KEY (gid);
> CREATE TABLE stat_parcels
> bgri11 character varying(11),
> CONSTRAINT bgri11_cascais_pkey PRIMARY KEY (gid)
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130503/3a6017e2/attachment.html>
