[postgis-users] Problem with gdalbuildvrt with no data collars on tiles...
Jae Ogilvie
jae.ogilvie at UNB.CA
Sat May 4 05:39:12 PDT 2013
Hello All,
I am new to the world of PostGIS and GDAL, but I'm looking for some help.
I've researched and it appears that gdalbuildvrt is supposed to be able to
resolve overlap areas when "no data values" are defined for the sources,
but I am unable to produce the expected results. Where elevation raster
values exist in the overlap areas, the values on both tiles are the same,
so I have no need for a computational mosaic, simply a merge of the data
which pays no attention to "no data" in either source raster.
I've tried the following workflow:
1. Set No data values to -999
gdal_translate -ot float32 -of gtiff -a_nodata -999 in_original.tif
out_nodata_defined.tif
2. Build VRT with specified source no data value
gdalbuildvrt -srcnodata -999 -hidenodata out.vrt
Am I doing something wrong?
<http://www.unb.ca/fredericton/forestry/people/ogilvie.html> Jae Ogilvie,
Research Associate
Faculty of Forestry & Environmental Management
University of New Brunswick
28 Dineen Drive
Fredericton, NB
Canada E3B 6C2
Tel. 506 451 6823 Fax. 506 453 3538
Web <http://watershed.for.unb.ca/> http://watershed.for.unb.ca/
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager.
This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130504/0235521c/attachment.html>
