[postgis-users] Need a method for "noding" a street network
Sandro Santilli
strk at keybit.net
Thu May 9 09:02:01 PDT 2013
Note that ST_Intersect may sligthly move the inputs while attempting
to catch robustness issues, so it's recommended to snap the final
set of intersection points to a grid and remove duplicates, then
finally snap each input segment to the so-found points to ensure
the are found on the lines they initially were computed from.
Out of curiosity: how much does ST_CreateTopoGeo takes when
passed the input as a collection ?
--strk;
On Thu, May 09, 2013 at 05:52:54PM +0200, Nicolas Ribot wrote:
> On 9 May 2013 15:43, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> > On 5/9/2013 7:20 AM, Nicolas Ribot wrote:
> >> (I spammed this thread a bit with image attachment....)
> >> Hi Steve,
> >> We the given dataset, my approach is indeed slow compared to st_union
> >> approach (though precision for the st_dwithin clause must be adapted to
> >> the current dataset. I took the following precision: 0.000001)
> >> The st_union method generates 18322 segments in 7318 ms, though the
> >> final association between original lines and new segment is not done
> >> here.
> >> With the query I gave, the st_dwithin part takes 11.7 sec on a recent
> >> laptop machine (1.8 Ghz Intel Core I7, 1024 mb of ram for shared_buffer,
> >> 512 for work_mem)...
> >> The complete query returns 17292 segments in 17956 ms.
> >> As the lines are almost already noded, it generates a lot of
> >> intersection points coincident with one line ends.
> >> As you noted, intermediate temp tables may help here:
> >> I decomposed the query into intermediate steps and the performance is
> >> about the same as with st_union :
> >> -- First creates temp table with intersection points
> >> drop table if exists intergeom;
> >> create temp table intergeom as
> >> select l1.id as l1id, l2.id as l2id,
> >> st_intersection(l1.geom, l2.geom) as geom
> >> from bdaways l1 join bdaways l2 on (st_dwithin(l1.geom, l2.geom,
> >> 0.000001))
> >> where l1.id <> l2.id ;
> >> -- keeps only true intersection points
> >> -- must handle the case where lines intersects at a linestring...
> > Would it make sense to take all the geometryType(geom) <> 'LINESTRING' and
> > just add the end points to the intergeom table. I think this would then add
> > break points at the ends of overlapping segments insure that they get
> > divided at those points and it would also add extraneous points at the
> > other end, but these would get filter out later. So add these two lines
> > here?
> You meant, geometryType(geom) = 'LINESTRING ?
> Yes it would make sense. I will try.
> > insert intergeom (l1id, l2id, geom)
> > values (l1id, l2id, st_startpoint(geom))
> > where geometryType(geom) <> 'LINESTRING';
> > values (l1id, l2id, st_endpoint(geom))
> > delete from intergeom where geometryType(geom) <> 'POINT';
> > I think some OSM data from a small central american country might make a
> > good test case. I have not tried any of these:
> > http://downloads.cloudmade.**com/americas/central_america<http://downloads.cloudmade.com/americas/central_america>
> > but I notice that if you click into a country like Belize or Costa Rica,
> > there is a shapefile for the country near the bottom of the list or you can
> > pick just a city for a smaller data set.
> > I'll start packaging this into a stored procedure. This is an awesome job.
> Thanks.
> I tested the costa rica highways dataset and found the following results:
> The query runs in about 28 seconds to process 29187 ways that are not at
> all connected between them.
> It generates 48415 segments.
> As an extra steps, all original ways that did not need to be cut by
> intersection points have to be added to the final results: these lines
> are already clean but were dismissed during the cutting process:
> insert into res (gid, sub_id, geom, type)
> select ways.gid, 1 as sub_id, ways.geom, geometryType(ways.geom)
> from ways
> where not exists (
> select res.gid from res where res.gid = ways.gid
> The result looks good, as all ways seems to be segmented (cf.
> http://sd-38177.dedibox.fr/img1.png and http://sd-38177.dedibox.fr/img2.png:
> black: initial lines, blue: new segments. Lines ends are shown as circles).
> A problem remains with non-simple or dirty lines as they self-intersect or
> have several ends and so are not noded properly.
> Though it should be simple to process them by identifying the problem. here
> is an example of such a line: http://sd-38177.dedibox.fr/img3.png
> I go looking at the procedure ;)
> Nicolas
