[postgis-users] Need a method for "noding" a street network
Nicolas Ribot
nicolas.ribot at gmail.com
Thu May 9 10:27:38 PDT 2013
Steve,
I modified your script to include the final step gathering all needed input
lines in the results table.
I also corrected the linestring ends insertion queries:
...quote_ident(n_geom) || ') <> ''LINESTRING'' '; to become:
...quote_ident(n_geom) || ') = ''LINESTRING'' ';
which inserted null values for geom column as st_startpoint(geom) is null
for any geometry <> LINESTRING.
It seems to work well on bdaways dataset and costa rica highways.
I will add some snapping operations as suggested by Sandro and try to see
if all segments are noded.
(Topology still creating after 4270 ms)
Nicolas
On 9 May 2013 18:44, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
> Thanks Sandro, I will try to add these snapping steps in the process.
> The following code:
> select dropTopology('topo1');
> SELECT topology.CreateTopology('topo1',4326, 0.000001);
> select st_createTopoGeo('topo1', st_collect(geom))
> from ways;
> Still runs after 1790 sec.
> Nicolas
> On 9 May 2013 18:02, Sandro Santilli <strk at keybit.net> wrote:
>> Note that ST_Intersect may sligthly move the inputs while attempting
>> to catch robustness issues, so it's recommended to snap the final
>> set of intersection points to a grid and remove duplicates, then
>> finally snap each input segment to the so-found points to ensure
>> the are found on the lines they initially were computed from.
>> Out of curiosity: how much does ST_CreateTopoGeo takes when
>> passed the input as a collection ?
>> --strk;
>> On Thu, May 09, 2013 at 05:52:54PM +0200, Nicolas Ribot wrote:
>> > On 9 May 2013 15:43, Stephen Woodbridge <woodbri at swoodbridge.com>
>> wrote:
>> > > On 5/9/2013 7:20 AM, Nicolas Ribot wrote:
>> > >> (I spammed this thread a bit with image attachment....)
>> > >> Hi Steve,
>> > >> We the given dataset, my approach is indeed slow compared to st_union
>> > >> approach (though precision for the st_dwithin clause must be adapted
>> to
>> > >> the current dataset. I took the following precision: 0.000001)
>> > >> The st_union method generates 18322 segments in 7318 ms, though the
>> > >> final association between original lines and new segment is not done
>> > >> here.
>> > >> With the query I gave, the st_dwithin part takes 11.7 sec on a recent
>> > >> laptop machine (1.8 Ghz Intel Core I7, 1024 mb of ram for
>> shared_buffer,
>> > >> 512 for work_mem)...
>> > >> The complete query returns 17292 segments in 17956 ms.
>> > >> As the lines are almost already noded, it generates a lot of
>> > >> intersection points coincident with one line ends.
>> > >> As you noted, intermediate temp tables may help here:
>> > >> I decomposed the query into intermediate steps and the performance is
>> > >> about the same as with st_union :
>> > >> -- First creates temp table with intersection points
>> > >> drop table if exists intergeom;
>> > >> create temp table intergeom as
>> > >> select l1.id as l1id, l2.id as l2id,
>> > >> st_intersection(l1.geom, l2.geom) as geom
>> > >> from bdaways l1 join bdaways l2 on (st_dwithin(l1.geom, l2.geom,
>> > >> 0.000001))
>> > >> where l1.id <> l2.id ;
>> > >> -- keeps only true intersection points
>> > >> -- must handle the case where lines intersects at a linestring...
>> > > Would it make sense to take all the geometryType(geom) <>
>> 'LINESTRING' and
>> > > just add the end points to the intergeom table. I think this would
>> then add
>> > > break points at the ends of overlapping segments insure that they get
>> > > divided at those points and it would also add extraneous points at the
>> > > other end, but these would get filter out later. So add these two
>> lines
>> > > here?
>> > You meant, geometryType(geom) = 'LINESTRING ?
>> > Yes it would make sense. I will try.
>> > > insert intergeom (l1id, l2id, geom)
>> > > values (l1id, l2id, st_startpoint(geom))
>> > > where geometryType(geom) <> 'LINESTRING';
>> > > values (l1id, l2id, st_endpoint(geom))
>> > > delete from intergeom where geometryType(geom) <> 'POINT';
>> > > I think some OSM data from a small central american country might
>> make a
>> > > good test case. I have not tried any of these:
>> > > http://downloads.cloudmade.**com/americas/central_america<
>> http://downloads.cloudmade.com/americas/central_america>
>> > > but I notice that if you click into a country like Belize or Costa
>> Rica,
>> > > there is a shapefile for the country near the bottom of the list or
>> you can
>> > > pick just a city for a smaller data set.
>> > > I'll start packaging this into a stored procedure. This is an awesome
>> job.
>> > Thanks.
>> > I tested the costa rica highways dataset and found the following
>> results:
>> > The query runs in about 28 seconds to process 29187 ways that are not at
>> > all connected between them.
>> > It generates 48415 segments.
>> > As an extra steps, all original ways that did not need to be cut by
>> > intersection points have to be added to the final results: these lines
>> > are already clean but were dismissed during the cutting process:
>> > insert into res (gid, sub_id, geom, type)
>> > select ways.gid, 1 as sub_id, ways.geom, geometryType(ways.geom)
>> > from ways
>> > where not exists (
>> > select res.gid from res where res.gid = ways.gid
>> > The result looks good, as all ways seems to be segmented (cf.
>> > http://sd-38177.dedibox.fr/img1.png and
>> http://sd-38177.dedibox.fr/img2.png:
>> > black: initial lines, blue: new segments. Lines ends are shown as
>> circles).
>> > A problem remains with non-simple or dirty lines as they self-intersect
>> or
>> > have several ends and so are not noded properly.
>> > Though it should be simple to process them by identifying the problem.
>> here
>> > is an example of such a line: http://sd-38177.dedibox.fr/img3.png
>> > I go looking at the procedure ;)
>> > Nicolas
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130509/98a39712/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130509/98a39712/attachment.obj>
