[postgis-users] line direction
Nicolas Ribot nicolas.ribot at gmail.com
Tue May 14 06:07:34 PDT 2013
If you want to materialize direction from start to end of line, you can use
st_startPoint and st_endpoint to determines the right ends.
What is your use case ?
Nicolas
On 14 May 2013 13:49, franco base <frenk.calza at gmail.com> wrote:
> Hi.
> I know tgis function but doesn't work.
> Myabe my question isn't correct.
> I'd have a binary value according to the arc direction.
> For example, in qgis I can view this information:
> I can see an arrow on my arc according to direction.
> I'd have the same using postgis.
> Thanks
> 2013/5/14 Paolo Corti <pcorti at gmail.com>
>> On Tue, May 14, 2013 at 6:03 PM, franco base <frenk.calza at gmail.com>
>> wrote:
>> > Hi.
>> > I have a question for the list.
>> > Is there a postgis function to have line direction?
>> http://postgis.refractions.net/docs/ST_Azimuth.html
>> regards
>> p
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130514/fca4f61b/attachment.html>
