[postgis-users] Strange behavior
    pcreso at pcreso.com
    Fri May 17 23:18:17 PDT 2013
There are two issues here.
I believe ST_AsText() does not return the full underlying precision of the point/line coordinates, so won't help resolve this.
Also, if you bear in mind your machine precision (or the Postgis coordinate precision - which may not be the same thing), the number of points on a linestring is finite, and makes the linestring actually a series of small steps. Think of it a bit like a series of pixels in a very fine raster. If horizontal or vertical, it works nicely, but any sort of diagonal & your line is only approximated. Two crossing diagonals do not necessarily have a pixel (point) in common.
A point using the value of pi as a coordinate - you can get very close, but "equals" is a meaningless operation.
Point on line intersections are therefore real number equality tests, and not reliable. Theoretically you can get different answers on 32/64 bit systems, or code compiled with different compilers (with different numerical precision), & if you export to any format that has reduced precision coordinates & re-import you can change the result as well.
This also applies to points very nearly "on" the boundary of a polygon being inside or outside.
This is an issue for me using postgis topologies. Creating nodes (as points) at the intersections of linestrings can result in very slightly shifted linestrings - not quite the same as the originals.
For point-on-line queries, using ST_Within() & a near zero number will find points very nearly on a line, there is no operation that can measure this exactly.
Cheers,
   Brent Wood
--- On Sat, 5/18/13, Richard Cernava <cernava at gmail.com> wrote:
Subject: [postgis-users] Strange behavior
To: postgis-users at lists.osgeo.org
Date: Saturday, May 18, 2013, 11:40 AM
I'm trying to query if a point is present inside a MultiLineString. When I run the following query I get very strange results in my opinion. If someone could elaborate as to what's going on it would be very much appreciated!
>From this query I get a false and a true on the identical data. First I check to see if the_geom intersects with my point and receive false. Second I take the_geom and convert it to text and then compare it with my point using ST_GeomFromText and get true. How is this possible? I've outputted the result from the statement below.
SELECT fullname, ST_X(ST_StartPoint(ST_LineMerge(the_geom))), ST_Y(ST_StartPoint(ST_LineMerge(the_geom))),ST_AsText(the_geom) AS text,ST_Intersects(the_geom, ST_GeomFromText('POINT(-122.837109 45.537746)', 4269)) AS fromdb,
ST_Intersects(ST_GeomFromText(ST_AsText(the_geom), 4269), ST_GeomFromText('POINT(-122.837109 45.537746)', 4269)) AS fromtxtfrom tiger_data.or_edges where   fullname like 'NW Norwich St' limit 1
"NW Norwich St";-122.837109;45.537746;"MULTILINESTRING((-122.837109 45.537746,-122.837253 45.537684,-122.837718 45.537368,-122.837829 45.537288,-122.838081 45.537108,-122.838169 45.537049))";f;t
-Richard
-----Inline Attachment Follows-----
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130517/84a54e8f/attachment.html>
