[postgis-users] 2.1.0beta3dev upgrade error
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 22 22:01:08 PDT 2013
Hi all,
I just tried to upgrade postgis from 2.0.3 -> 2.1.0beta3dev and got the
following error:
pgr_test=# alter extension postgis update to '2.1.0beta3dev';
ERROR: could not load library
"/usr/lib/postgresql/9.2/lib/postgis-2.1.so":
/usr/lib/postgresql/9.2/lib/postgis-2.1.so: undefined symbol:
json_tokener_errors
Did I forget a step or do something wrong?
-Steve
I have json-c-0.11 built and installed. In fact is is the ./configure
report:
PostGIS is now configured for i686-pc-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
SQL preprocessor: /usr/bin/cpp -traditional-cpp -P
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.3.8
GDAL config: /usr/local/bin/gdal-config
GDAL version: 1.9.2
PostgreSQL config: /usr/lib/postgresql/9.2/bin/pg_config
PostgreSQL version: PostgreSQL 9.2.4
PROJ4 version: 47
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.8
JSON-C support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets:
dblatex:
convert:
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
