[postgis-users] Shp2pgsql : Error in fread()
Donovan Cameron
sault.don at gmail.com
Thu May 23 11:17:42 PDT 2013
Hey Hugues,
I was recently trying to load large shapefiles and a filegdb into
postgis 2.0 too.
I had a +170 million point file (filegdb) and a +1 million record
polygon (shapefile).
Using shp2pgsql would get so far and crash for me as well with similar errors.
I found that I could instead make use of the pgdump
(http://www.gdal.org/ogr/drv_pgdump.html) driver from gdal!
I also used some other parameters and lco to make it work smoothly.
ogr2ogr --config PG_USE_COPY YES -gt 65536 -f PGDump output.sql
input.shp -lco GEOMETRY_NAME=geom -lco SCHEMA=schema -lco
CREATE_SCHEMA=OFF -lco SPATIAL_INDEX=OFF
Instead of making a .sql file, the bottom of the drv_pgdump page has a
nice example on how to pipe the output directly into psql if you want
to try that.
# use COPY instead of INSERT commands (speeds it up)
PG_USE_COPY YES
# amount of records to insert on each iteration
-gt 65536
# name the output geom field "geom" instead of "wkb_geometry", replace if needed
GEOMETRY_NAME=geom
# update schema with your actual output schema
SCHEMA=schema
# do not create the schema (it probably exists already! Omit this
option if the schema needs to be created)
CREATE_SCHEMA=OFF
# don't create the GIST index on the geom field, speeds up process
significantly (we do this manually after!)
SPATIAL_INDEX=OFF
Once the sql file is made, you can then use ogr2ogr again to import
that to your postgis database or just do the pipe trick instead of
making another output file (save disk space and time!)
I also found that logging into the database via the psql terminal
would work just as well, also gets you to the place needed to run the
GiST index creation afterwards.
In psql, once connected to the desired database, use the \i command:
\i C:/Path/to/output.sql
But you will then have to create the GIST index on the geom field from
psql or pgadmin with a query like this:
CREATE INDEX tablename_geom_gist
ON schema.tablename
USING gist
(geom);
Replace geom, schema and tablename as needed.
Setup the needed read/write permissions and you are good to go!
Donovan
On Tue, May 21, 2013 at 12:43 PM, Hugues François
<hugues.francois at irstea.fr> wrote:
> Hello,
> Thanks for your answer. It took me some times to reply because I tried to make test with spliting the shape file : it takes quite a long time to work with million of polygons.
> If I'm not wrong, the ticket you linked to is about dbf size and has been fixed in 1.5.3. On my side, shp is effectively more than 2 Go but dbf file is near 1.5 Go and I work with postgis 2.0.1.
> However, I tried to select the first 10.000.000'th rows and then the last ones within arcgis to export data as a new shapefile. Despite there was no error when I exported the data (or when I reopen it), this time I wasn't able to export the second part of the table further than I could import in postgis.
> Finally, I don't know where the problem is exactly but I think it's on the arcgis side.
> Hugues.
