[postgis-users] RE : Need help with update table from a select query
Hugues François hugues.francois at irstea.fr
Fri May 24 11:21:31 PDT 2013
Hello,
You should try :
update nodes a
set outline_id = b.outline_id
from outlines b
where st_contains(b.geom, a.geom)
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at lists.osgeo.org de la part de Clifford Snow
Date: ven. 24/05/2013 19:24
À: PostGIS Users Discussion
Objet : [postgis-users] Need help with update table from a select query
I need some help figuring out how to update a table. I'm trying to get the
polygon id that a node resides in. I have two tables, one of outlines and
another with nodes. I want to add the id of the outline the node is
contained in to the node.
my thought was this query:
update nodes set outline_id = (select outline_id from oulines, nodes where
st_contains(outline.geom, nodes,geom))
But this query returns more than one row. What am I doing wrong?
Thanks
Clifford
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130524/3f74a7a6/attachment.bin>
