[postgis-users] Error updating PostGIS
Paragon Corporation
lr at pcorp.us
Thu Nov 7 14:17:01 PST 2013
The safest is to do a backup and restore. The restoration will use the
newest postgis you have unless you pre-install a new db with CREATE
EXTENSION postgis VERSION "something"
Normally I'd advice to just copy the postgis--2.0.0-2.1.0.sql to
postgis--2.0.0alpha7SVN-2.1.0.sql and repeat your ALTER EXTENSION
but I recall some major breaking changes (last minute ondisk I think)
between the 2.0.0 beta1 and 2.0.0 beta2 that would necessitate a dump
restore otherwise you'd run into issues down the line.
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Thursday, November 07, 2013 4:57 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Error updating PostGIS
On Thu, Nov 07, 2013 at 03:47:52PM -0600, Armando Pardo Zepeda wrote:
> Please, I need help to update a database with a postgis version of
> "POSTGIS="2.0.0alpha7SVN" to PostGIS 2.1.0 in Debian Wheezy
> I already tried with:
> ALTER EXTENSION postgis UPDATE TO "2.1.0" but it returns the error
> message:
> ERROR: extension "postgis" has no update path from version
> "2.0.0alpha7SVN" to version "2.1.0"
See where you can go to from "2.0.0*":
ls `pg_config --sharedir`/extension/postgis--2.0.0*
--strk;
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
