[postgis-users] radically different performance on different machines
Rémi Cura
remi.cura at gmail.com
Fri Nov 8 07:49:07 PST 2013
Hey Richard,
I may be completely wrong, but maybe you could use ST_DWithin instead of
Buffer+intersect.
It is usually a good boost in perf, but maybe you absolutely need this
shrinking.
In the same way I'm not sure the way this query is written is the best (you
really need a subquerry here?).
I'm guessing you don't have a simple index on your "name" from
"special_district", it will accelerate it.
(CREATE INDEX ON special_district (name);)
Last thing is you may consider to protect your column name "owner" and
"name" as these are reserved sql word, using doublequote
Hope it helps =)
Cheers,
Rémi-C
2013/11/8 Sandro Santilli <strk at keybit.net>
> On Fri, Nov 08, 2013 at 07:58:45AM -0700, Richard Greenwood wrote:
> > I have a query that runs in <1 second on one machine and 47 seconds on
> > another. The postgres and postgis versions are bascially the same. The
> > database and query are the same. But "explain" is different on the two.
> The
> > query is below and the graphic output of pgAdmin explain is attached.
> > Obviously, my question is - why the difference?
> Different statistics gathered ? Try running ANALYZE on both systems.
> Different cost configuration ? Compare postgresql.conf.
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131108/173def86/attachment.html>
