[postgis-users] PostGIS 2.1.1 Released
J Smith dark.panda+lists at gmail.com
Mon Nov 11 12:12:38 PST 2013
I'm getting a build error on CentOS 5.10 using the stock gcc 4.1.2
concerning an undefined reference to isfinite:
../liblwgeom/.libs/liblwgeom.so: undefined reference to `isfinite'
The specific file that references isfinite that is causing the issue
is liblwgeom/g_box.c. Adding the following to the top of the file will
resolve the issue:
#ifndef _GNU_SOURCE
#define _GNU_SOURCE
#endif
Apparently this version of gcc is old enough that isfinite will not be
defined in math.h without _GNU_SOURCE being defined first.
Should I start up a ticket for this?
