[postgis-users] Grid of points inside Polygon
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Wed Nov 13 08:49:28 PST 2013
You can use ST_PixelAsCentroids(ST_AsRaster()) to generate a regular grid of points inside a polygon.
Pierre
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Rémi Cura
> Sent: Wednesday, November 13, 2013 6:41 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Grid of points inside Polygon
> This would be an improvement but still non efficient.
> you have 2 possibilities, supposing that what you want is points 20 meter
> spaced in all road_buf :
> either you compute for each road_buffer the points inside, one road at a
> time ( figuratively ).
> This means you write a function which generates points 20-meter
> spaced in the bounding box of the road you are working on, and keep those
> in the real road buffer, and group result points as a multipoints (for
> cosmetic purpose)
> You would then use it like this :
> SELECT road_id, points_insidea_road(the_geom) AS
> my_points_inside_the_road
> FROM road_polygons_table
> You would have as output a line per road with a multipoint
> containing all the point 20 meter spaced inside the road.
> Or (what you wrote) you generate all points and keep those intersecting
> one or many road.
> The first one is mandatory, because it avoids to manipulate (incredibly) big
> table of all points spaced by 20 meters for UK (around 500 * 10^6 points ! )
> Even with indexes it's not a good idea to use such number of rows.
> That's the first point (write a function working for one road, then use it for
> all road).
> The second point is the way you compute is very inefficient. If your road is
> going from south-West to NorthEast, you will generate a very big number of
> points, and very few will be in the road_buffer. This is problematic as for a
> road of only 20 kms, you may generate as many as 100k points and keep
> only few of them. If you want to process hundreds of ks or roads it will
> become very problematic. Also you would have to generate points each
> time.
> So here is what I suggest you : change your strategy :
> instead of generating all point in bounding box and then keeping only those
> in road_buffer,
> generate a line every 20 meters going North south and an line every 20
> meters going East-West , then use the function ST_Intersection to keep only
> part of this lines being inside the road_polygon, then you have the points
> inside road_polygons as the intersections of these EW lines with the SN
> lines.
> It will be very efficient because you can create a table with all the lines going
> East-West and South-North for great britain (about 25k + 50k lines), and
> build index on it (index on geom and on the column saying if it is SN or EW).
> The trick is the number of lines is around 500km * 50 line/km + 1000km *
> 50 line/km , where the number of points is 500km * 50 line/km * 1000km
> * 50 line/km
> Hope it helps,
> Cheers,
> Rémi-C
> 2013/11/13 James David Smith <james.david.smith at gmail.com>
> Hey Remi,
> Thanks for your reply. So in your mind you think we should have a
> database of say 300 polygons, and then we run a command like this
> right?
> SELECT
> ST_Collect(st_setsrid(ST_POINT(x,y),27700))
> FROM
> generate_series(53320::int, 667380::int,20) as x,
> generate_series(7780::int, 1226580::int,20) as y,
> road_polygons_table
> WHERE
> st_intersects(road_polygons_table.the_geom,
> What do you think?
> Thanks
> James
> On 11 November 2013 14:51, Rémi Cura <remi.cura at gmail.com>
> wrote:
> > Hey,
> > the whole point on using a sgbds like postgis is using index.
> > If you have one line you don't use indexes...
> > So in short, don't make one polygon with a buffer of all the road,
> but a
> > table with a line for the buffer for every road, then do you
> computation to
> > create grid of points inside of polygons, then union the result of
> points!
> > And it s always a bad idea to run a function on big data when you
> have not
> > tested it fully (including scaling behavior) on small data.
> > Cheers
> > Rémi-C
> > 2013/11/11 James David Smith <james.david.smith at gmail.com>
> >> Hi all,
> >> Would appreciate some advice on the best way to accomplish
> this please.
> >> Our situation is that we have a single polygon which has been
> created
> >> by buffering all of the major roads in the UK. Projection is
> OSGB36
> >> (27700). Obviously it's quite a big polygon.
> >> --> SELECT st_area(geom) FROM roadbufferunion;
> >> st_area
> >> 77228753220.8271
> >> What we now want to do is create a regular grid of 20 metre x 20
> metre
> >> points instead the polygon area. So we wrote this function
> (based on
> >> some googling, apologies for not being able to recall the exact
> person
> >> who originally wrote it):
> >> CREATE OR REPLACE FUNCTION makegrid(geometry, integer,
> integer)
> >> RETURNS geometry AS
> >> 'SELECT ST_Collect(st_setsrid(ST_POINT(x,y),$3)) FROM
> >> generate_series(53320::int, 667380::int,$2) as x
> >> ,generate_series(7780::int, 1226580::int,$2) as y
> >> where st_intersects($1,st_setsrid(ST_POINT(x,y),$3))'
> >> LANGUAGE sql
> >> and we then run this by doing the following:
> >> SELECT st_x((ST_Dump(makegrid(geom, 20, 27700))).geom) as x,
> >> st_y((ST_Dump(makegrid(geom, 20, 27700))).geom) as y INTO
> grid_points
> >> from roadbufferunion;
> >> However after over 2 days of the query running on a pretty
> powerful
> >> linux cluster, we still have no result. I'm not sure if it is
> >> actually running or not to be honest.
> >> Does the query look right?
> >> Any ideas how we can make it run quicker?
> >> Thanks
> >> James
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at lists.osgeo.org
> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
