[postgis-users] Grid of points inside Polygon
Rémi Cura
remi.cura at gmail.com
Wed Nov 13 10:04:08 PST 2013
All lines should be in one table, you can add a column to differentiate
between line going SN and EW,
this is what the query I wrote does.
Not changing your code much, it gives for the line table :
CREATE TABLE all_lines tablespace jamestabs AS
( SELECT st_setsrid(st_makeline(st_makepoint(x, 7780), st_makepoint(x,
1226580)),27700) as the_geom, 'SN' AS direction
FROM generate_series(53320::int, 667380::int, 20) as x)
UNION
( SELECT st_setsrid(st_makeline(st_makepoint(53320, y),
st_makepoint(667380, y)),27700) as the_geom, 'EW' AS direction
FROM generate_series(7780::int, 1226580::int, 20) as y)
then building index on it.
"-- Merge the road buffer polygons into one big polygon
-- Should maybe consider leaving them as they are, but am merging for now.
SELECT st_union(geom) as geom INTO union_roads FROM ukmajrdbuffer;"
*You must not do it ! *
As I told you "blabla index blabla".
instead, create an index on table ukmajrdbuffer, and use it without
unioning.
Then you query is not going to work at all ... (or *very very* slowly)
"FROM east_to_west, north_to_south, buff_union_roads" : it potentially
generates 1000*50*1000*50 * number_of_road rows to filter, very bad idea,
you'll get the same problem as with points...
(please see some example on internet to understand WITH, it is simple
, useful, and makes query much more clear)
First you could try :
CREATE TABLE lines_for_each_road tablespace jamestabs AS
WITH all_lines AS ( --this subquerry gets all the lines
SELECT *
FROM all_lines
SELECT row_number() over() AS id--,*
FROM ukmajrdbuffer, all_lines
WHERE ST_Intersects(ukmajrdbuffer.the_geom, all_lines.the_geom)=TRUE;
This will give you (if you uncomment the "--,*", ), for every road, all the
lines intersecting the road
example :
road_1 | line_2_EW
road_1 | line_3_EW
road_1 | line_78_SN
road_1 | line_7_EW
road_2 ...
*How long is it (don't uncomment plz), and how many rows do you get (select
count(*) from lines_for_each_road )?*
If it is not too long, we will go on and "cut" the lines so that for every
road, we keep the part of the lines that are inside the road_buffer.
(I have to leave now, tomorrow)
Cheers,
Rémi-C
2013/11/13 James David Smith <james.david.smith at gmail.com>
> Hey Remi,
> I don't quite get what the query you gave does to be honest. But
> working with some of the ideas and notions you gave me I have put the
> below together. The final bit of the code is the key query. The tables
> of NS and EW lines were done very quickly. Nice. But now doing the
> 'intersects within polygon' is taking some time so I'll see how it
> gets on when I get in to work tomorrow morning:
> DROP TABLE IF EXISTS north_to_south;
> DROP TABLE IF EXISTS east_to_west;
> -- Make a table of north to south lines
> CREATE TABLE north_to_south tablespace jamestabs AS
> FROM generate_series(53320::int, 667380::int, 20) as x);
> -- Add an index
> CREATE INDEX north_to_south_geom_index ON north_to_south USING GIST (
> the_geom );
> -- Make a table of east to west lines
> CREATE TABLE east_to_west tablespace jamestabs AS
> FROM generate_series(7780::int, 1226580::int, 20) as y);
> -- Add an index
> CREATE INDEX east_to_west_geom_index ON east_to_west USING GIST ( the_geom
> -- Import the Road Buffer file using the pg_loader interface
> -- Update the geometry field as the loader didn't seem to do this.
> SELECT UpdateGeometrySRID('ukmajrdbuffer','geom',27700);
> -- The unioned roads file isn't valid geom. So I simplify it a little
> to make it valid.
> -- We simplify with a 70 metres factor. Geom is now valid.
> SELECT ST_SimplifyPreserveTopology(geom, 70) AS geom INTO
> buff_union_roads FROM union_roads;
> -- Now calculate the points where the lines intersect and also where
> they are within the polygon.
> CREATE TABLE gridpoints tablespace jamestabs
> AS (SELECT ST_Intersection(east_to_west.the_geom, north_to_south.the_geom)
> WHERE st_within(buff_union_roads.geom,
> ST_Intersection(east_to_west.the_geom, north_to_south.the_geom)) =
> TRUE);
> Thanks
> James
> On 13 November 2013 13:33, Rémi Cura <remi.cura at gmail.com> wrote:
> > Using the lines you exactly do the same as with points.
> > The lines will be spaced exactly by 20 meters, end and start being
> exactly
> > on the 20 meters grid, line being either perfectly veritcla or perfectly
> > horizontal.
> > So intersections are guaranteed to be on the 20 meter grid, because this
> is
> > the definition of a 20 meter grid =) .
> > Here is a not optimal way to do it :
> > For instance if UK is enclosed in a bouding box (xmin,ymin,xmax,ymax),
> where
> > xmin-max and ymin-max are rounded to the nearest 20 meters multiple (ie
> x or
> > y % 20 = 0)
> > (Please note that this is not clever because we generate too much SN
> lines,
> > GB being only 500 km wide at most, so we would need to filter, but you
> don't
> > care, following would take less than a minute anyway, and you need to do
> it
> > only once).
> > WITH minmax AS (
> > SELECT xmin,ymin,xmax,ymax, bbox_of_england
> > WITH series AS (
> > SELECT s
> > FROM generate_series(0,1000*(1000/20)::bigint,20) AS s --casting to
> bigint
> > to be safe against going over int limit
> > WITH lines AS (
> > SELECT ST_MakeLine (ST_MakePoint(xmin+s,ymin),ST_MakePoint(xmin+s,ymax))
> AS
> > lineSN,
> > ST_MakeLine(ST_MakePoint(xmin, ymin+s), ST_MakePoint(xmax,ymin+s) AS
> lineEW
> > FROM series, minmax
> > unioned_lines AS (
> > SELECT lineSN AS line, 'SN' as direction
> > FROM lines,minmax
> > WHERE ST_Interesects(lineSN,bbox_of_england)= TRUE
> > UNION
> > SELECT lineEW AS line, 'EW' AS direction
> > FFROM lines,minmax
> > WHERE ST_Interesects(lineEW,bbox_of_england)= TRUE
> > SELECT row_number() over() AS uid, line, direction
> > FROM unioned_line
> > then creating table and index on geom and on direction (and possibly on
> uid,
> > but better create a primary key then if you use it)
> > Of course I didn't test this query, but you should be able to use it
> easily.
> > Cheers,
> > Rémi-C
> >> Hi Remi,
> >> Apologies. One more thing which I am not sure about. We need the
> >> final grid of points that we make to be multiples of 20. For example:
> >> 53320, 7780 = Yes
> >> 53323, 7780 = No
> >> 53320, 7794 = No
> >> 53321, 7754 = No
> >> That is why in the original function that we wrote, we put the numbers
> >> in as below.
> >> SELECT ST_Collect(st_setsrid(ST_POINT(x,y),$3)) FROM
> >> generate_series(53320::int, 667380::int,$2) as x
> >> ,generate_series(7780::int, 1226580::int,$2) as y
> >> where st_intersects($1,st_setsrid(ST_POINT(x,y),$3))'
> >> We did this because the points in the grid have to 'align' with the
> >> values of mutliple 20.
> >> If we do the N-S and E-W lines solution that you suggest, I don't
> >> think that this will work will it?
> >> Thanks
> >> James
> >> On 13 November 2013 11:49, James David Smith
> >> <james.david.smith at gmail.com> wrote:
> >> > Hi Remi,
> >> > Thanks so much for this detailed response. Your idea about creating
> >> > the lines and the only storing where they intersect and are within the
> >> > polygons is a great idea. I'm going to give that a go now.
> >> > Thanks again,
> >> > James
> >> > On 13 November 2013 11:41, Rémi Cura <remi.cura at gmail.com> wrote:
> >> >> This would be an improvement but still non efficient.
> >> >> you have 2 possibilities, supposing that what you want is points 20
> >> >> meter
> >> >> spaced in all road_buf :
> >> >> either you compute for each road_buffer the points inside, one road
> at
> >> >> a
> >> >> time ( figuratively ).
> >> >> This means you write a function which generates points 20-meter
> spaced
> >> >> in
> >> >> the bounding box of the road you are working on, and keep those in
> the
> >> >> real
> >> >> road buffer, and group result points as a multipoints (for cosmetic
> >> >> purpose)
> >> >> You would then use it like this :
> >> >> SELECT road_id, points_insidea_road(the_geom) AS
> >> >> my_points_inside_the_road
> >> >> FROM road_polygons_table
> >> >> You would have as output a line per road with a multipoint containing
> >> >> all
> >> >> the point 20 meter spaced inside the road.
> >> >> Or (what you wrote) you generate all points and keep those
> intersecting
> >> >> one
> >> >> or many road.
> >> >> The first one is mandatory, because it avoids to manipulate
> >> >> (incredibly) big
> >> >> table of all points spaced by 20 meters for UK (around 500 * 10^6
> >> >> points ! )
> >> >> Even with indexes it's not a good idea to use such number of rows.
> >> >> That's the first point (write a function working for one road, then
> use
> >> >> it
> >> >> for all road).
> >> >> The second point is the way you compute is very inefficient. If your
> >> >> road is
> >> >> going from south-West to NorthEast, you will generate a very big
> number
> >> >> of
> >> >> points, and very few will be in the road_buffer. This is problematic
> as
> >> >> for
> >> >> a road of only 20 kms, you may generate as many as 100k points and
> keep
> >> >> only
> >> >> few of them. If you want to process hundreds of ks or roads it will
> >> >> become
> >> >> very problematic. Also you would have to generate points each time.
> >> >> So here is what I suggest you : change your strategy :
> >> >> instead of generating all point in bounding box and then keeping
> only
> >> >> those
> >> >> in road_buffer,
> >> >> generate a line every 20 meters going North south and an line every
> 20
> >> >> meters going East-West , then use the function ST_Intersection to
> keep
> >> >> only
> >> >> part of this lines being inside the road_polygon, then you have the
> >> >> points
> >> >> inside road_polygons as the intersections of these EW lines with the
> SN
> >> >> lines.
> >> >> It will be very efficient because you can create a table with all the
> >> >> lines
> >> >> going East-West and South-North for great britain (about 25k + 50k
> >> >> lines),
> >> >> and build index on it (index on geom and on the column saying if it
> is
> >> >> SN or
> >> >> EW).
> >> >> The trick is the number of lines is around 500km * 50 line/km +
> 1000km
> >> >> * 50
> >> >> line/km , where the number of points is 500km * 50 line/km * 1000km
> >> >> 50
> >> >> line/km
> >> >> Hope it helps,
> >> >> Cheers,
> >> >> Rémi-C
> >> >>> Hey Remi,
> >> >>> Thanks for your reply. So in your mind you think we should have a
> >> >>> database of say 300 polygons, and then we run a command like this
> >> >>> right?
> >> >>> SELECT
> >> >>> ST_Collect(st_setsrid(ST_POINT(x,y),27700))
> >> >>> FROM
> >> >>> generate_series(53320::int, 667380::int,20) as x,
> >> >>> generate_series(7780::int, 1226580::int,20) as y,
> >> >>> road_polygons_table
> >> >>> WHERE
> >> >>> st_intersects(road_polygons_table.the_geom,
> >> >>> What do you think?
> >> >>> Thanks
> >> >>> James
> >> >>> On 11 November 2013 14:51, Rémi Cura <remi.cura at gmail.com> wrote:
> >> >>> > Hey,
> >> >>> > the whole point on using a sgbds like postgis is using index.
> >> >>> > If you have one line you don't use indexes...
> >> >>> > So in short, don't make one polygon with a buffer of all the road,
> >> >>> > but a
> >> >>> > table with a line for the buffer for every road, then do you
> >> >>> > computation
> >> >>> > to
> >> >>> > create grid of points inside of polygons, then union the result of
> >> >>> > points!
> >> >>> > And it s always a bad idea to run a function on big data when you
> >> >>> > have
> >> >>> > not
> >> >>> > tested it fully (including scaling behavior) on small data.
> >> >>> > Cheers
> >> >>> > Rémi-C
> >> >>> > 2013/11/11 James David Smith <james.david.smith at gmail.com>
> >> >>> >> Hi all,
> >> >>> >> Would appreciate some advice on the best way to accomplish this
> >> >>> >> please.
> >> >>> >> Our situation is that we have a single polygon which has been
> >> >>> >> created
> >> >>> >> by buffering all of the major roads in the UK. Projection is
> OSGB36
> >> >>> >> (27700). Obviously it's quite a big polygon.
> >> >>> >> --> SELECT st_area(geom) FROM roadbufferunion;
> >> >>> >> st_area
> >> >>> >> 77228753220.8271
> >> >>> >> What we now want to do is create a regular grid of 20 metre x 20
> >> >>> >> metre
> >> >>> >> points instead the polygon area. So we wrote this function (based
> >> >>> >> on
> >> >>> >> some googling, apologies for not being able to recall the exact
> >> >>> >> person
> >> >>> >> who originally wrote it):
> >> >>> >> CREATE OR REPLACE FUNCTION makegrid(geometry, integer, integer)
> >> >>> >> RETURNS geometry AS
> >> >>> >> 'SELECT ST_Collect(st_setsrid(ST_POINT(x,y),$3)) FROM
> >> >>> >> LANGUAGE sql
> >> >>> >> and we then run this by doing the following:
> >> >>> >> SELECT st_x((ST_Dump(makegrid(geom, 20, 27700))).geom) as x,
> >> >>> >> st_y((ST_Dump(makegrid(geom, 20, 27700))).geom) as y INTO
> >> >>> >> grid_points
> >> >>> >> from roadbufferunion;
> >> >>> >> However after over 2 days of the query running on a pretty
> powerful
> >> >>> >> linux cluster, we still have no result. I'm not sure if it is
> >> >>> >> actually running or not to be honest.
> >> >>> >> Does the query look right?
> >> >>> >> Any ideas how we can make it run quicker?
> >> >>> >> Thanks
> >> >>> >> James
> >> >>> >> _______________________________________________
> >> >>> >> postgis-users mailing list
> >> >>> >> postgis-users at lists.osgeo.org
> >> >>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131113/bee9edf5/attachment.html>
