[postgis-users] Grid of points inside Polygon
James David Smith
james.david.smith at gmail.com
Fri Nov 15 06:57:23 PST 2013
Hey Remi,
Do you think before I try running the big query you have just sent me,
that I should go back and try to get the original file of uk roads? I
mean the very original file that has not had any buffers applied or
any merging done.
Or shall we just go for it and see if it has finished when I come into
work on Monday?! haha.
Thanks
James
On 15 November 2013 14:01, Rémi Cura <remi.cura at gmail.com> wrote:
> Outch,
> you have only 8 roads in GB? =)
> This is not going to go fast till you don't have some dozens k's of roads.
> I'm guessing you are not at will to send those roads?
> The next step will be (when you'll be sure everything is OK)
> CREATE TABLE lines_for_each_road AS
> WITH all_lines AS (
> SELECT *
> FROM all_lines
> cutted_lines AS ( --we cut the line to keep only part of lines inside
> road_buffer
> SELECT ST_Intersection(all_lines.the_geom,ukmajrdbuffer.geom) as
> lines_cutted, direction
> FROM ukmajrdbuffer, all_lines
> WHERE ST_Intersects(ukmajrdbuffer.geom, all_lines.the_geom)=TRUE
> cutted_lines_SN AS ( --this is the cutted lines which going from South to
> North
> SELECT *
> FROM cutted_lines
> WHERE direction = 'SN'
> cutted_lines_EW AS ( --this is the cutted lines going from East toWest
> SELECT *
> FROM cutted_lines
> WHERE direction = 'EW'
> points AS ( -- we take the intersection of EW lines with SN lines , that is
> the points on the grid.
> SELECT ST_Intersection(clSN.lines_cutted, clEW.lines_cutted) AS point
> FROM cutted_lines_SN as clSN, cutted_lines_EW AS clEW
> WHERE ST_Intersects(clSN.lines_cutted, clEW.lines_cutted)=TRUE --no point ot
> compute an intersection if lines don't intersect
> SELECT row_number() over() AS id , point
> FROM points ;
> Cheers,
> Rémi-C
> 2013/11/15 James David Smith <james.david.smith at gmail.com>
>> Hey Remi,
>> I'll do a few checks and get back to you. Maybe I did something wrong
>> because I set this query going on my local PostgreSQL installation but
>> also on our Linux Cluster machine which is much more powerful. And it
>> finished on my local installation BEFORE the cluster. So maybe I did
>> something wrong on the local query.
>> The query that has finished took about 1 hour.
>> The query on our cluster is still running.
>> select count(*) from ukmajrdbuffer = 8
>> This is because before I was given the data the roads buffer had
>> already been dissolved unfortunately.
>> James
>> On 15 November 2013 13:43, Rémi Cura <remi.cura at gmail.com> wrote:
>> > Good !
>> > Something is strange with the result,
>> > you get only 190k lines intersecting road buffer,
>> > it is very few , I expected at least 10times this!
>> > How many time took this computing by the way?
>> > How many road buffer geom do you have ? (select count(*) from
>> > ukmajrdbuffer
>> > Cheers,
>> > Rémi-C
>> >> Hey.
>> >> Yes, it's done. Was just getting some lunch! :-)
>> >> select count(*) from lines_for_each_road
>> >> Result = 187033
>> >> I have also just ran 'VACUUM ANALYZE' on the tables
>> >> 'lines_for_each_road' as well as the table 'all_lines'
>> >> I also can confirm that I have ran the following commands:
>> >> CREATE INDEX all_lines_index ON all_lines USING GIST ( the_geom )
>> >> CREATE INDEX ukmajrdbuffer_index ON ukmajrdbuffer USING GIST (geom);
>> >> Should we now uncomment this line from the previous query?
>> >> " SELECT row_number() over() AS id--,* "
>> >> Thanks again Remi,
>> >> James
>> >> On 15 November 2013 13:14, Rémi Cura <remi.cura at gmail.com> wrote:
>> >> > Also if you do have indexes,
>> >> > can you run a "VACUUM ANALYZE", so that the indexes will be used?
>> >> > Cheers,
>> >> > Rémi-C
>> >> > 2013/11/15 Rémi Cura <remi.cura at gmail.com>
>> >> >> It should be finished by now,
>> >> >> can you check you have geom indexes on :
>> >> >> "ukmajrdbuffer.geom" and "all_lines.the_geom"
>> >> >> How many geoms do you have in "ukmajrdbuffer"?
>> >> >> Cheers,
>> >> >> Rémi-C
>> >> >>> Hey Sandro,
>> >> >>> Thanks for this, it is at least twice faster =)
>> >> >>> Cheers,
>> >> >>> Rémi-C
>> >> >>>> Thanks both. Geometries now fixed.
>> >> >>>> The query 'CREATE TABLE lines_for_each_road....' has now been set
>> >> >>>> running. Will report back when it's done. I suspect it may take a
>> >> >>>> while!
>> >> >>>> James
>> >> >>>> On 15 November 2013 11:03, Sandro Santilli <strk at keybit.net>
>> >> >>>> wrote:
>> >> >>>> > On Fri, Nov 15, 2013 at 11:50:42AM +0100, Rémi Cura wrote:
>> >> >>>> >> Yep, maybe something like
>> >> >>>> >> UPDATE ukmajrdbuffer SET the_geom = ST_MakeValid(the_geom)
>> >> >>>> >> WHERE ST_IsValid(the_geom) = FALSE
>> >> >>>> > ST_MakeValid internally checks for ST_IsValid, so no need
>> >> >>>> > to add the condition (which would run the test twice).
>> >> >>>> > --strk;
>> >> >>>> > _______________________________________________
>> >> >>>> > postgis-users mailing list
>> >> >>>> > postgis-users at lists.osgeo.org
>> >> >>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
