[postgis-users] Grid of points inside Polygon
James David Smith
james.david.smith at gmail.com
Fri Nov 15 07:40:44 PST 2013
Remi,
Ok. Cool. I've set the below query running. On Monday I will also
attempt to get the original road lines file too. Let's see if we have
a result on Monday.
CREATE TABLE lines_for_each_road AS
WITH all_lines AS (
SELECT *
FROM all_lines
cutted_lines AS ( --we cut the line to keep only part of lines inside
road_buffer
SELECT ST_Intersection(all_lines.the_geom,ukmajrdbuffer.geom) as
lines_cutted, direction
FROM ukmajrdbuffer, all_lines
WHERE ST_Intersects(ukmajrdbuffer.geom, all_lines.the_geom)=TRUE
cutted_lines_SN AS ( --this is the cutted lines which going from South to North
SELECT *
FROM cutted_lines
WHERE direction = 'SN'
cutted_lines_EW AS ( --this is the cutted lines going from East toWest
SELECT *
FROM cutted_lines
WHERE direction = 'EW'
points AS ( -- we take the intersection of EW lines with SN lines ,
that is the points on the grid.
SELECT ST_Intersection(clSN.lines_cutted, clEW.lines_cutted) AS point
FROM cutted_lines_SN as clSN, cutted_lines_EW AS clEW
WHERE ST_Intersects(clSN.lines_cutted, clEW.lines_cutted)=TRUE --no
point ot compute an intersection if lines don't intersect
SELECT row_number() over() AS id , point
FROM points ;
Thanks
James
On 15 November 2013 15:37, Rémi Cura <remi.cura at gmail.com> wrote:
> You should try to get the original road file, because i will be very easy to
> reapply some buffer and filtering to keep only major road.
> Yet, why not let it run during the week end?
> Cheers,
> Rémi-C
> 2013/11/15 James David Smith <james.david.smith at gmail.com>
>> Hey Remi,
>> Do you think before I try running the big query you have just sent me,
>> that I should go back and try to get the original file of uk roads? I
>> mean the very original file that has not had any buffers applied or
>> any merging done.
>> Or shall we just go for it and see if it has finished when I come into
>> work on Monday?! haha.
>> Thanks
>> James
>> On 15 November 2013 14:01, Rémi Cura <remi.cura at gmail.com> wrote:
>> > Outch,
>> > you have only 8 roads in GB? =)
>> > This is not going to go fast till you don't have some dozens k's of
>> > roads.
>> > I'm guessing you are not at will to send those roads?
>> > The next step will be (when you'll be sure everything is OK)
>> > WITH all_lines AS (
>> > SELECT *
>> > FROM all_lines
>> > road_buffer
>> > to
>> > North
>> > SELECT *
>> > FROM cutted_lines
>> > SELECT *
>> > FROM cutted_lines
>> > that is
>> > point ot
>> > FROM points ;
>> > Cheers,
>> > Rémi-C
>> >> Hey Remi,
>> >> I'll do a few checks and get back to you. Maybe I did something wrong
>> >> because I set this query going on my local PostgreSQL installation but
>> >> also on our Linux Cluster machine which is much more powerful. And it
>> >> finished on my local installation BEFORE the cluster. So maybe I did
>> >> something wrong on the local query.
>> >> The query that has finished took about 1 hour.
>> >> The query on our cluster is still running.
>> >> select count(*) from ukmajrdbuffer = 8
>> >> This is because before I was given the data the roads buffer had
>> >> already been dissolved unfortunately.
>> >> James
>> >> On 15 November 2013 13:43, Rémi Cura <remi.cura at gmail.com> wrote:
>> >> > Good !
>> >> > Something is strange with the result,
>> >> > you get only 190k lines intersecting road buffer,
>> >> > it is very few , I expected at least 10times this!
>> >> > How many time took this computing by the way?
>> >> > How many road buffer geom do you have ? (select count(*) from
>> >> > ukmajrdbuffer
>> >> > Cheers,
>> >> > Rémi-C
>> >> >> Hey.
>> >> >> Yes, it's done. Was just getting some lunch! :-)
>> >> >> select count(*) from lines_for_each_road
>> >> >> Result = 187033
>> >> >> I have also just ran 'VACUUM ANALYZE' on the tables
>> >> >> 'lines_for_each_road' as well as the table 'all_lines'
>> >> >> I also can confirm that I have ran the following commands:
>> >> >> CREATE INDEX all_lines_index ON all_lines USING GIST ( the_geom )
>> >> >> CREATE INDEX ukmajrdbuffer_index ON ukmajrdbuffer USING GIST (geom);
>> >> >> Should we now uncomment this line from the previous query?
>> >> >> " SELECT row_number() over() AS id--,* "
>> >> >> Thanks again Remi,
>> >> >> James
>> >> >> On 15 November 2013 13:14, Rémi Cura <remi.cura at gmail.com> wrote:
>> >> >> > Also if you do have indexes,
>> >> >> > can you run a "VACUUM ANALYZE", so that the indexes will be used?
>> >> >> > Cheers,
>> >> >> > Rémi-C
>> >> >> > 2013/11/15 Rémi Cura <remi.cura at gmail.com>
>> >> >> >> It should be finished by now,
>> >> >> >> can you check you have geom indexes on :
>> >> >> >> "ukmajrdbuffer.geom" and "all_lines.the_geom"
>> >> >> >> How many geoms do you have in "ukmajrdbuffer"?
>> >> >> >> Cheers,
>> >> >> >> Rémi-C
>> >> >> >>> Hey Sandro,
>> >> >> >>> Thanks for this, it is at least twice faster =)
>> >> >> >>> Cheers,
>> >> >> >>> Rémi-C
>> >> >> >>>> Thanks both. Geometries now fixed.
>> >> >> >>>> The query 'CREATE TABLE lines_for_each_road....' has now been
>> >> >> >>>> set
>> >> >> >>>> running. Will report back when it's done. I suspect it may take
>> >> >> >>>> a
>> >> >> >>>> while!
>> >> >> >>>> James
>> >> >> >>>> On 15 November 2013 11:03, Sandro Santilli <strk at keybit.net>
>> >> >> >>>> wrote:
>> >> >> >>>> > On Fri, Nov 15, 2013 at 11:50:42AM +0100, Rémi Cura wrote:
>> >> >> >>>> >> Yep, maybe something like
>> >> >> >>>> >> UPDATE ukmajrdbuffer SET the_geom = ST_MakeValid(the_geom)
>> >> >> >>>> >> WHERE ST_IsValid(the_geom) = FALSE
>> >> >> >>>> > ST_MakeValid internally checks for ST_IsValid, so no need
>> >> >> >>>> > to add the condition (which would run the test twice).
>> >> >> >>>> > --strk;
>> >> >> >>>> > _______________________________________________
>> >> >> >>>> > postgis-users mailing list
>> >> >> >>>> > postgis-users at lists.osgeo.org
>> >> >> >>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
