[postgis-users] The first release of the PostGIS Add-ons is out!
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Nov 18 09:13:47 PST 2013
Humm.. Lots of requirements...
> Sorry for the license, I needed a clear answer :-) I personnaly would prefere
> LGPL, like postgres.
Doesn't seems like a good idea to make it different than PostGIS. How is LGPL different from LPG? I'm a license ignorant.
> can you consider to use a template doc (wiki in github?, or pure markdown)
> , more detailled than just in code comment? I feel the current PostGIS doc
> per function should be a lower limit of documentation.
There is a quick list of available functions at the beginning of the file. I would rather go for less maintenance as possible. If you want to copy/remove the doc from the file to the wiki. Feel free to do it.
> Also important : you may quickely go to several dozens of functions, why
> not decide now for an architecture (classifying the contrib), maybe with
> label, maybe with classical folders? Like "raster", "util", "rewrite", etc etc.
A small step at a time...
> Last : what is the process for a contrib to be accepted? Surely it should be
> tested by another personn than dev before being added?
I wrote some criterias at the beginning of the file. It goes like this:
-your function is written in pure PL/pgSQL (no C!),
-your function is generic enough to be useful to other PostGIS users,
-you follow functions and variables naming and indentation conventions already in use in the files,
-you document your function like the ones already provided,
-you provide some tests in the postgis_addons_test.sql file,
-you add the necessary DROP statements in the postgis_addons_uninstall.sql file.
Pierre
