[postgis-users] ST_SetValue problem
Hugues François
hugues.francois at irstea.fr
Tue Nov 19 07:04:23 PST 2013
Hello,
Did you try with a new raster
CREATE TABLE schema.data_raster_newval AS
SELECT rid, ST_SetValue(rast,1, geom, 100) AS RAST
FROM schema.data_raster, schema.data_vector
What is the result ?
Since you have only one tile, I don't think the intersect statement will really improve performances.
Hugues.
-----Message d'origine-----
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Sebastian Schutte
Envoyé : mardi 19 novembre 2013 14:42
À : postgis-users at lists.osgeo.org
Objet : [postgis-users] ST_SetValue problem
Dear Postgis list,
I have been struggling for a while with a seemingly simple raster operation in postgis. I have a small number of quadratic polygons arranged like a chessboard. The cells of this chessboard contain values like elevation that I would like to write into a much larger raster layer with one band. To check whether I was on the right track with ST_SetValue, I tried to set the raster values of the cells that intersect with any of my polygons to some value (100 in this example):
UPDATE schema.data_raster SET rast = ST_SetValue(rast,1, geom, 100)
FROM schema.data_vector
I also tried a variant with "WHERE ST_Intersects(rast,geom)"
The raster dataset has only one tile, but I assumed this would not be important for the task at hand (expect maybe for longer runtimes of the query).
ST_SetValue is supposed to work with arbitrary geometries:
http://postgis.net/docs/RT_ST_SetValue.html . The result is that I change raster values in only 1 of the 81 polygon cells that I have in schema.data_vector. What am I missing here? Thanks for your help! Keep up the great work!
All the best,
Sebastian
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
