[postgis-users] simplifying (homogenize) a polygon
Nicolas Ribot
nicolas.ribot at gmail.com
Thu Nov 21 03:42:37 PST 2013
Hi Denis,
In your example, I don't understand how the parts of your
multipolygons can be adjacent. Are they valid ?
Do you have a visual example ?
Thank you
Nicolas
On 21 November 2013 07:32, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hello Rémi,
> I was hoping a simplest request without enabling topology but thanks anyway!
> Cheers,
> Denis
> On 20. 11. 13 18:26, Rémi Cura wrote:
> From what I understand of your needs, Postigs topology was designed for
> this.
> Cheers,
> Rémi-C
> 2013/11/20 Denis Rouzaud <denis.rouzaud at gmail.com>
>> Hi all,
>> I am drawing some multipolygons in QGIS and sometimes, I have parts of
>> them which are adjacent and I'd like to homogenize them to have less parts
>> and no adjacent parts.
>> I could do this with a quite complex method:
>> 1. get the number of parts Z:
>> SELECT ST_NumGeometries(geometry) FROMmytable WHERE id=123;
>> 2. do the simplification using ST_CollectionHomogenize:
>> SELECT
>> ST_Multi(ST_CollectionHomogenize(ST_Union(ST_GeometryN(geometry,n)))) FROM
>> mytable CROSS JOIN generate_series(1,Z) n WHERE id = 123;
>> 3. update manually the result in the table (copy paste).
>> Does someone has something more straightforward???
>> Thanks a lot!
>> Best regards,
>> Denis
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
