[postgis-users] simplifying (homogenize) a polygon
Nicolas Ribot
nicolas.ribot at gmail.com
Thu Nov 21 06:47:07 PST 2013
Thanks for the explanation.
You could correct the multipolygons in one step, by using the
st_buildArea function, that "merges" a linework of linestrings,
preserving holes.
To extract polygons boundaries as linestring, st_boundary() is very handy:
The "bad_multipg" table contains invalid multipolygons with adjacent
parts (http://imgur.com/MP6Cy4f)
select gid, st_buildArea(st_boundary(geom))
from bad_multipg
group by gid;
Gives: http://imgur.com/RqlowFI
Nicolas
On 21 November 2013 13:50, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi Nicolas,
> I edit my multi polygons in QGIS, and you're right the geometry becomes
> invalid if some parts have adjacent segments.
> In a simple case, I would have a multi polygons with 3 parts with 2 parts
> adjacent.
> http://imgur.com/zvxPFeR
> Although the geometry is invalid, my intention is to make it valid, and
> therefore merge the two parts, which is impossible in QGIS - AFAIK.
> So my intention was to save the geometry as this, and make it valid by a
> command.
> I could achieve this with a function:
> CREATE OR REPLACE FUNCTION distribution.simplemultipoly(geom geometry)
> RETURNS geometry AS
> $BODY$
> DECLARE
> num_geom integer;
> BEGIN
> SELECT ST_NumGeometries(geom) into num_geom;
> SELECT
> ST_Multi(ST_CollectionHomogenize(ST_Union(ST_GeometryN(geom,n))))
> FROM generate_series(1,num_geom) n
> INTO geom;
> RETURN geom;
> END;
> $BODY$
> LANGUAGE plpgsql;
> But I wondered if there was a more direct way.
> Cheers,
> Denis
> On 21. 11. 13 12:42, Nicolas Ribot wrote:
> Hi Denis,
> In your example, I don't understand how the parts of your
> multipolygons can be adjacent. Are they valid ?
> Do you have a visual example ?
> Thank you
> Nicolas
> On 21 November 2013 07:32, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hello Rémi,
> I was hoping a simplest request without enabling topology but thanks anyway!
> Cheers,
> Denis
> On 20. 11. 13 18:26, Rémi Cura wrote:
> From what I understand of your needs, Postigs topology was designed for
> this.
> Cheers,
> Rémi-C
> 2013/11/20 Denis Rouzaud <denis.rouzaud at gmail.com>
> Hi all,
> I am drawing some multipolygons in QGIS and sometimes, I have parts of
> them which are adjacent and I'd like to homogenize them to have less parts
> and no adjacent parts.
> I could do this with a quite complex method:
> 1. get the number of parts Z:
> SELECT ST_NumGeometries(geometry) FROMmytable WHERE id=123;
> 2. do the simplification using ST_CollectionHomogenize:
> SELECT
> ST_Multi(ST_CollectionHomogenize(ST_Union(ST_GeometryN(geometry,n)))) FROM
> mytable CROSS JOIN generate_series(1,Z) n WHERE id = 123;
> 3. update manually the result in the table (copy paste).
> Does someone has something more straightforward???
> Thanks a lot!
> Best regards,
> Denis
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
