[postgis-users] simplifying (homogenize) a polygon
Nicolas Ribot
nicolas.ribot at gmail.com
Thu Nov 21 07:02:51 PST 2013
You welcome.
In fact, thanks to you: I used to extract multipolygons boundaries
with such queries (!!):
st_exteriorRing((st_dumpRings(
(st_dump(geom)).geom
)).geom) as geom
until your use case makes me remember st_boundary function :)
Nicolas
On 21 November 2013 15:51, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> wow, thanks a lot!
> indeed, much much nicer!
> thanks again,
> Denis
> On 21. 11. 13 15:47, Nicolas Ribot wrote:
>> Thanks for the explanation.
>> You could correct the multipolygons in one step, by using the
>> st_buildArea function, that "merges" a linework of linestrings,
>> preserving holes.
>> To extract polygons boundaries as linestring, st_boundary() is very handy:
>> The "bad_multipg" table contains invalid multipolygons with adjacent
>> parts (http://imgur.com/MP6Cy4f)
>> select gid, st_buildArea(st_boundary(geom))
>> from bad_multipg
>> group by gid;
>> Gives: http://imgur.com/RqlowFI
>> Nicolas
>> On 21 November 2013 13:50, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>>> Hi Nicolas,
>>> I edit my multi polygons in QGIS, and you're right the geometry becomes
>>> invalid if some parts have adjacent segments.
>>> In a simple case, I would have a multi polygons with 3 parts with 2 parts
>>> adjacent.
>>> http://imgur.com/zvxPFeR
>>> Although the geometry is invalid, my intention is to make it valid, and
>>> therefore merge the two parts, which is impossible in QGIS - AFAIK.
>>> So my intention was to save the geometry as this, and make it valid by a
>>> command.
>>> I could achieve this with a function:
>>> CREATE OR REPLACE FUNCTION distribution.simplemultipoly(geom geometry)
>>> RETURNS geometry AS
>>> $BODY$
>>> DECLARE
>>> num_geom integer;
>>> BEGIN
>>> SELECT ST_NumGeometries(geom) into num_geom;
>>> SELECT
>>> ST_Multi(ST_CollectionHomogenize(ST_Union(ST_GeometryN(geom,n))))
>>> FROM generate_series(1,num_geom) n
>>> INTO geom;
>>> RETURN geom;
>>> END;
>>> $BODY$
>>> LANGUAGE plpgsql;
>>> But I wondered if there was a more direct way.
>>> Cheers,
>>> Denis
>>> On 21. 11. 13 12:42, Nicolas Ribot wrote:
>>> Hi Denis,
>>> In your example, I don't understand how the parts of your
>>> multipolygons can be adjacent. Are they valid ?
>>> Do you have a visual example ?
>>> Thank you
>>> Nicolas
>>> On 21 November 2013 07:32, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>>> Hello Rémi,
>>> I was hoping a simplest request without enabling topology but thanks
>>> anyway!
>>> Cheers,
>>> Denis
>>> On 20. 11. 13 18:26, Rémi Cura wrote:
>>> From what I understand of your needs, Postigs topology was designed for
>>> this.
>>> Cheers,
>>> Rémi-C
>>> 2013/11/20 Denis Rouzaud <denis.rouzaud at gmail.com>
>>> Hi all,
>>> I am drawing some multipolygons in QGIS and sometimes, I have parts of
>>> them which are adjacent and I'd like to homogenize them to have less
>>> parts
>>> and no adjacent parts.
>>> I could do this with a quite complex method:
>>> 1. get the number of parts Z:
>>> SELECT ST_NumGeometries(geometry) FROMmytable WHERE id=123;
>>> 2. do the simplification using ST_CollectionHomogenize:
>>> SELECT
>>> ST_Multi(ST_CollectionHomogenize(ST_Union(ST_GeometryN(geometry,n))))
>>> FROM
>>> mytable CROSS JOIN generate_series(1,Z) n WHERE id = 123;
>>> 3. update manually the result in the table (copy paste).
>>> Does someone has something more straightforward???
>>> Thanks a lot!
>>> Best regards,
>>> Denis
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
