[postgis-users] shp2pgsql failing on large shp
Rémi Cura remi.cura at gmail.com
Thu Nov 21 08:15:42 PST 2013
If you are desperate,
I think you can use OGR directly.
Good luck,
Cheers,
Rémi-C
2013/11/21 Sandro Santilli <strk at keybit.net>
> On Thu, Nov 21, 2013 at 12:59:16PM +0100, Paolo Cavallini wrote:
> > I have hit the issue:
> > http://trac.osgeo.org/postgis/ticket/393
> > on a large file. I have PostGIS 1.5.1-5 in production on Debian squeeze,
> so I cannot
> > upgrade it on that machine. It is unclear to me, after reading the
> ticket, what is
> > the best way to solve this.
> Did you try using shp2pgsql from a newer PostGIS version ?
> It should work just fine.
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131121/2d820acc/attachment.html>
