[postgis-users] operator && return errors where st_overlaps or st_intersects does not
Huub Fleuren
huub.fleuren at geodan.nl
Thu Nov 21 09:01:47 PST 2013
i upgraded to 1.5.8 without succes, where is 1.5.9?
I did the folowing
wget http://download.osgeo.org/postgis/source/postgis-1.5.8.tar.gz
<http://download.osgeo.org/postgis/source/postgis-1.5.8.tar.gz>
(where is 1.5.9?)
tar xvzf postgis-2.1.1.tar.gz
cd postgis-2.1.1
./configure
make
sudo su postgres
psql -f postgis_upgrade_15_minor.sql -d soils
it CREATE FUNCTION many times and also skipped a lote of functions
SELECT postgis_full_version();
POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.6" USE_STATS (procs from 1.5 r
10612 need upgrade)
(1 row)
On 11/21/2013 5:27 PM, Sandro Santilli wrote:
>> September 2009" LIBXML="2.7.6" USE_STATS
> Memory corrupting bugs have been fixed by version later than 1.5.2.
> Try reproducing with 1.5.9.
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
*Geodan*
Buitenhaven 27-A
5211 TP 's-Hertogenbosch (NL)
T +31 (0)73 - 692 5151
E huub.fleuren at geodan.nl <mailto:huub.fleuren at geodan.nl>
www.geodan.nl <http://www.geodan.nl/> | disclaimer
<http://www.geodan.nl/disclaimer>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131121/e93215b7/attachment.html>
