[postgis-users] operator && return errors where st_overlaps or st_intersects does not
Huub Fleuren huub.fleuren at geodan.nl
Thu Nov 21 10:11:34 PST 2013
On 11/21/2013 6:37 PM, Sandro Santilli wrote:
> On Thu, Nov 21, 2013 at 06:01:47PM +0100, Huub Fleuren wrote:
>> i upgraded to 1.5.8 without succes, where is 1.5.9?
i guess 1.5.9will come soon
By the way: i did NOT use make install, because it is an upgrade no?
Should i run make install? The version upgrade was not reflected in
postgis_full_version()
> Did you run postgis_full_version() in the "soils" database ?
Yes
> What do you mean by "skipped a lot of functions" ?
It is the response from running the SQL
looks like
CREATE FUNCTION
CREATE FUNCTION
DROP CAST
CREATE CAST
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
DROP FUNCTION
psql:postgis_upgrade_15_minor.sql:5154: NOTICE:  function
st_geom_accum(geometry                                 [],geometry) does
not exist, skipping
DROP FUNCTION
psql:postgis_upgrade_15_minor.sql:5155: NOTICE:  function
collect_garray(geometr                                 y[]) does not
exist, skipping
Regards, Huub
**E huub.fleuren at geodan.nl <mailto:huub.fleuren at geodan.nl>
<http://www.geodan.nl/disclaimer>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131121/c0eb0789/attachment.html>
